Chassis collision sensors
2755 12 2019-8-12
Jovanthan
Flight distance : 45364 ft
Taiwan
Has anyone tried this? My S1 has been programmed to take actions when  “chassis hits an obstacle” , however no actions has been taken after it physically hitting obstacles..........
Armors sensors works perfectly for me by the way!
Deeply appreciated for your experience sharing!!
2019-8-12
BGA
I did not try this yet but, just to be sure, did you enable the chassis accelerator before trying to detect hitting an object? I am pretty sure it uses an accelerometer for this, not the hit detectors in the armor.
2019-8-12
BGA
In fact, if you can paste the code you used here, I may be able to help.
2019-8-12
Jovanthan
Taiwan
BGA Posted at 8-12 07:35
My bad!  It’s working now!
It can only be triggered above a certain speed, no actions taken in low speed conditions like 0.2m/s or 0.3m/s...
Thank you so much for helping!!!
2019-8-12
BGA
Jovanthan Posted at 8-12 08:14
No worries. Glad you managed to sort it up.
2019-8-12
DJI Stephen
Hello and good day Jovanthan. Thank you for reaching out and it is great to know that you have fixed the said issue. Have a safe and a happy driving and programming always.
2019-8-12
Jovanthan
Taiwan
DJI Stephen Posted at 8-12 09:46
Thank you & have a nice day
2019-8-12
MarkusXL
That was only one small success - and you have many more ahead of you!  Keep trying different things and don't give up!
2019-8-12
Jovanthan
Taiwan
MarkusXL Posted at 8-12 17:58
I love this forum!
2019-8-13
DJI Stephen
Jovanthan Posted at 8-12 16:21
You are always welcome Jovanthan. Have a safe driving  and a happy programming always.
2019-8-16
PeloPincho
Hi All
How did you manage to make it work?, I've tried at different speeds with the chassis accelerator enabled without success. Find below the small program that I used for testing this
I do manage to stop the chassis when a target is recognised, but this beats me....
Any help will be appreciated
2020-1-11
BGA
PeloPincho Posted at 1-11 05:40
Hi All
It looks like this should work. I tried the example in the programming guide using the on-spot check instead of the callback and it worked. It might be a problem with the callback code. I will try your code later and see.
2020-1-11
PeloPincho
Thanks, it does seem an issue with this callback. I've tried other callbacks like the "marker identified" one from the smart section and they work like a charm. Most likely it is something that I'm overlooking, but I haven't been able to figure it out.
I've noticed that there are some sensitivity settings for the armor, but I can't find anything of that sort for the chassis accelerometer. Pity that the armor shields can't be used for obstacle detection...
2020-1-11
