fansfe82067d
OK, some more info on this. I've just been trying out a new USB-C to Lightning cable with the extension rod, and right away I ran into the problem with being unable to turn on the Pocket. The attempt causes the red light to flash continuously on the rod handle. This reminded me that when I had the problem some days ago, it was also when trying out a different (longer) cable.
The immediate fix seems to be to disconnect the USB-C cable from the Pocket. Disconnecting the phone end doesn't work. The red light will then turn off, and you can turn on the Pocket with the appropriate button on the rod. After doing that about 3 times, it was no longer necessary to disconnect the cable - the rod was able to turn on the Pocket with the cable attached. A bit of a pain, but easier than removing the Pocket itself from the rod.
I've now left the Pocket connected to the rod and to the phone for a while, and later I will see if the problem is still resolved, or whether the interval will make it happen again.
By the way, with a 1 metre cable, if I wind it loosely round the extension rod about five times, it stays reasonably neat when extending or folding the rod. I'm inclined to use the cable in future rather than the wireless module, which takes longer to start up with the app, and which must cause some battery drain.
Hopefully someone at DJI can comment on what's happening here. |
