A J
Flight distance : 13877205 ft
Firstly, there is no warranty on just the props at all. As best practice you should inspect the props before every flight and replace them if there are any indentations, splits, cracks, deep scratches etc or if they feel loose when attached to the corresponding motor. On the basis that you have not crashed the drone and the props appear fine they are good to be used. I have read that DJI state the props should be replaced every 200 flights but that is a general rule. Some commercial pilots replace props after several flights whilst others will fly their drones for a couple of years without replacing them. It's your call. There is no definitive number of flights or flight hours but 200 without crashing/damaging them seems a good figure to work with. |
