I work for a public safety agency in Southern California. Currently we fly the Matrice 210 with the Z30 and XT cameras, depending on the mission. We also fly the Phantom 4 Pro and Sparks, again depending on the mission. We have been operational since 2017 and we have almost 100 missions completed. I say this to point out that our team is not completely new to operating UAS aircraft.
Back in July, we flew the Phantom 4 Pro on what seemed to be a simple mission. The weather was clear and wind speeds were in the 5-10 MPH range with some gusts up to around 15 MPH. Nothing really remarkable, and nothing we have not operated in before.
The Phantom was about 50’AGL and almost directly above the remote pilot who had the controller with him. The flight was fine for about 2-3 minutes, and the battery had be discharged to about 59%. The pilot received a “High Wind Warning” on the Phantom, which is sometimes common. Without any other warning the Phantom completely shut off, fell directly to the ground, causing major damage.
We sent it back to DJI and paid the $65 for data retrieval. We are more concerned about the “why” of the crash because of the nature and liability of being a public agency. Below is DJI’s response:
Thank you for your patience.
This is XXX from the Technical Support team, and I will be assisting you on this case from now on for related inquiries about data analysis.
Here's the result of the data analysis on your case number: CAS-XXXXXXXXXXXXX.
The power shutoff in mid-air due to the high wind environment giving the battery a lot of pressure to maintain the battery in mid air.
We can still proceed with the repair, however, you will cover the repair charges.
Your understanding and cooperation will be highly appreciated. Best regards, XXXXXXX Question: Has anyone else had this happen to them?
Does anyone know why this could have happened?
