First time using Smart Controller (i believe mine is defective)
879 4 2019-8-14
bobsma
please note: I have the Spark Controller and Mavic 2 Pro Standard Controller for a comparision.
Is it normal for the Smart Controller to have the Left wheel that controls the Gimbal to have a friction point or click when moving the wheel in one direction? The right wheel is smooth moving in both directions as I would expect. And for my Spark and standard controller... Both wheels (left and right) are smooth in operation. Seems like bad quality control or a built in design that doesn't make any sense?
2019-8-14
Adam9997
Flight distance : 2608901 ft
I don’t think so, both wheels on my controller are smooth. Very similar feel to the standard controller.
2019-8-14
bobsma
Adam9997 Posted at 8-14 14:44
i know... i just wanted to make sure. i wonder if there is a zoom view on the Mavic 2 Pro because everything is so small on the Smart Controller. This makes it more difficult to line up the shot when you are dealing with smaller objects. no wonder people are attaching another monitor.. but then it defeats the purpose unless you like to use a Very heavy controller or use a tripod all the time. Plus the added cost! so because of the defect... I get to try it out for a little longer to really decide if I would like to exchange it or purchase a new one down the road.
2019-8-15
ff22
On SOME Android devices, a triple tap will magnify the screen but my SC is not available at the moment and I don't know if it works on the SC.  Also, there may be a setting that enables it.
2019-8-16
bobsma
ff22 Posted at 8-16 05:54
thanks.  I think a lot of people are in denial, that having such a small screen will not hinder your results. If you are stuck with this Smart Controller, you can make it into something much better by adding a larger monitor to it. plus there is a lot of Glare even though it's so bright.
2019-8-16
