How to enable “discreet mode” with XT2 on M200 V2?
4101 5 2019-8-15
DrMrdalj
Flight distance : 1265978 ft
Serbia
Is there any M200 V2 user who knows how to turn off the arm lights when using XT2?
I use M210 RTK V2, Cendence+Crystalsky and latest DJI Pilot app - and I can’t find a way to enable “discreet mode” when using XT2 (that is how its named in DJI promo text)or any other setting that would turn off red and green arm lights...With Z30 such option appears under camera setting Menu.
On M200 V1 in GO app there is “smart arm lights” setting as wrll,  but still no similar option when XT2 is used in DJI Pilot (which happens to be only app available for M200 V2).
So, am I overlooking something obvious? Is there option to get simple feature that is in promo materials?
2019-8-15
DrMrdalj
Serbia
I have tested with XT2 and there is no option for smart lights or discreete mode.
With Z30 here is option to enable smart ligts  under camera setting Menu.
So, topic is  "how to enable discreete mode with XT2 on M200 V2"!
2019-8-15
Hi DrMrdalj, please refer to the screenshot below to turn off the arm lights. 1.png 2.png
2019-8-16
DrMrdalj
Serbia
DJI Mindy Posted at 8-16 02:00
Hi DrMrdalj, please refer to the screenshot below to turn off the arm lights.[view_image][view_image][Image]
Dear DJI Mindy, please note that such option DOES NOT exist when using XT2 on M200 V2. I have checked many times, and it is confirmed by another XT2-M200 V2 owner. Here are the puctures of XT2 menu...
2019-8-16
DrMrdalj
Serbia
I haven’t tried to start the M200 V2 without any camera - it is possible that such option would exist if XT2 wasn’t on the aircraft..
2019-8-16
DrMrdalj
Serbia
DrMrdalj Posted at 8-16 18:00
So, I found an answer for myself and I share it here for anyone interested in same topic:
To diabale arm lights and other lights you shouldn't mount XT2. If XT2 is your only camera then just turn on the aircraft without any camera mounted - and then in Pilot app  you will find Smart LED settings under camera menu. After changing settings to your needs then restart the aircraft with XT2.
If/when you mount XT2 then camera menu gets different and you do not see Smart LED settings, despite previously set LED option will remain.
2019-8-18
