Haggi
Flight distance : 2581785 ft
Norway
Statement:
'The theoretical max flight time 16 minutes (no wind at a consistent 12.4 mph (20 kph)), and the max hover time is 15 minutes (no wind), power consumption will speed up due to the different flight environment and usage of sticks.'
You can hardly reach these numbers, but what's your Spark's max flight time?
Open your GO 4 app, and via menu you can open the Flight Record section.
You should be able to sort your records by tapping Time.
Do not post screenshots, you are a pilot..we trust you!
But we love stories. Please share :-)
DISCLAIMER:
- Do not try to push your limits to improve your maximum flight times, we do not want to hear about lost Sparks.
- The only situation where forced RTH will happen, is when connection is lost between remote and aircraft.
- If you cancel any onscreen low battery warning about RTH, there will be no automatic RTH.
- At 10% battery, your Spark will start forced landing! Will be initiated earlier if your Spark needs more battery to land safely.
- You will be able to have some control, most important is to push stick to gain height.
- If you are concerned about battery health, do not drain your battery below 10-15%.
