tankinnen
Flight distance : 1893 ft
Hello. I have a Mavic Air that I have flown maybe 20 or 30 times. Recently I started having an issue with the gimbal but it is intermittent. One moment the vertical gimbal control works fine (in pre-flight tests for example) but a minute later either the vertical movement is restricted, or the gimbal fails to respond to the vertical gimbal control wheel on the RC at all. Auto calibration of the gimbal seems to suggest full freedom of movement (it seems to move to vertical and horizontal extremes with no problem and the calibration completes successfully) but when in flight the problem returns. I don't get any errors at the moment but I have seen the gimbal overloaded message a few times in the past.
I can't see this specific problem discussed anywhere - has anyone else had this problem or can recommend a fix? Drone has had one minor ground impact when it seemed to miscalculate ground level (IMU recal fixed that) and has been exposed to some dust (I am in North West Australia). Not sure if this can contribute?
Many thanks.
Tank.
