Autotune problem, incorrect motor parameters
4764 10 2019-8-16
haeton
Ukraine
Hi there,
Have the next problem with my Ronin SC:
Perfectly balanced A7III with Tamron 28-75 ( all parameters after test - excellent)
After performing Auto Tune motor parameters goes to this:  Pan-60, Tilt -50, Roll-60
With these parameters motors sound like they have extra power on them...and after tilting camera motors start to vibrate like overloaded. So parameters are definitely wrong.
Working on the default parameters ( Pan-15, Tilt -8, Roll-10) is absolutely OK, no problems at all. No sound from motors, no vibrating, no overloading...like it should be...
So what is the problem with Autotune can be? Everybody recommends it, but it doesn't work in my case...how to solve?
Thanks!
Autotune
Autotune
2019-8-16
fans589cba4b
Flight distance : 12780633 ft
thats strange. for me I have to boost the numbers up by about 20 on each axis to avoid shakiness.
2019-8-16
mikeev261
Having similar issues (link to my thread) with larger lenses (but still under the 2 kg limit). Balance test is 3X excellent. For me, after auto-tune I have to lower the tilt (up/down) power by 5-10 to not have a "groaning" sound at certain angles.
Something tells me that a firmware update (we haven't had any yet, right?) will likely clean this up. @DJI Mindy, is anyone working on this problem (or at least aware of it)?
2019-8-18
haeton
Ukraine
mikeev261 Posted at 8-18 12:36
Try to use manual settings like me...For example, I use 15 8 10. On this settings no strange sound from motors and everything works fine.
I hope that the firmware update will solve this problem, but strange that nobody talking about that, everybody recommending autotune and seems like everything works fine for them...
Waiting for some replay from DJI...
2019-8-18
mikeev261
haeton Posted at 8-18 13:30
Yeah, like I said (with my 24mm GM) when I scale back the motor strength it *seems* ok. With lighter lenses I have no issues at all though- autotune works fine.
2019-8-18
haeton
Ukraine
mikeev261 Posted at 8-18 13:52
A little update...
I just come back from the 1st test shooting with Ronin SC...I was working with parameters 15-8-10 ( default)...and I was thinking that everything is OK...but it wasn't))
When I opened files on a big screen all footages was shaky...and now I understand that it is caused by not right motor parameters...and honestly, I didn't expect something like this after my Crane II...
So 2 minutes ago I made fast test with parameters that was made by Autotune ( near 58 -60-58, something like that) and it works...footage is perfect...BUT in some positions motors vibrating!...and motors now making sound all time, like small bugs flying)
I'm very interested is it normal, and why gimbal vibrating with setup lower than 1.5kg...
2019-8-18
mikeev261
haeton Posted at 8-18 14:46
A little update...
Try autotuning and then making a far more subtle decrease to see if it gets rid of your shakes. I think reverting to the default values will be too weak.
2019-8-18
mikeev261
mikeev261 Posted at 8-18 17:46
FWIW I'm still seeing this with the new firmware (v1.1.0.0). And I'm getting the same results on AutoTune.
2019-8-29
YonLee
Indonesia
Same here im still dont understand why the auto tune not working properly  still shaky footage or jitter please update this issue
2019-9-1
AntaresTech
Are you using the autotune PRO version?
2019-9-14
fansebabfad3
AntaresTech Posted at 9-14 17:52
What Autotune Pro is? There is only one app for ronin SC...
Working with SC for 1 month very actively...autotune works OK, no problem...if lowering parameters so footage becomes shaky....if using autotune everything is OK. Sometimes motors vibrating just a little when tilting to much but it doesn't affect the footage...
2019-9-27
