Flygmaskin
Flight distance : 70719 ft
Hi there,
So sorry to hear about the flyaway! It sure sucks.. I was very close myself several times to loose it thanks to it going to ATTI-mode.
In ATTI, it's a way different thing to control the aircraft, since there is no GPS (the GPS is what makes the AC able to stay still in the wind), the AC will go with the wind, and it will go fast! Therefore, the pilot will have to compensate for this, with manual input on the control sticks.
This day, you did not have very much wind (according to the log), atleast on the ground level, but ~120-130 m up is a different story.
As far as I know, yes, your friend must find the drone in order to use the DJI care. But he can always try to submit a data log to DJI and ask them to check it.
The Spark will auto land when the battery is low enough. No fixed battery % value of when this will happen I think, but the smart battery calculates this depending on distance/altitude and some other factors.
Anyway, lots of errors in that log!
11m 49s comes first Yaw Error (repeated 12 times)
11m 50s Here comes Atti, and the Spark is imediately taken by the wind.
11m 50s more yaw error (repeated 10 times)
11m 51s Yaw Error. Magnetic Filed Interference
The magnetic interference warning is something I never got in my logs. I am not as skilled as some other people here, so I can't say for sure if this was an actual real problem, or just an error that the AC throwed, after the yaw error.
Having said that, it is possible that your buddy caught some magnetic interference on the ground. Looks like he took off from ground made of stone, close to asphlat and perhaps close to parked cars? If there is concrete around, there is almost always metall bars in the concrete. You should always, each and every time, make sure that no metal objects are close. As I understand it, the AC compass can pick up the interference, compensate for it in some way, and when you are up in the air, getting away from the interference, the compass will go crazy.
In this case, I find it unlikely that he caught too much magnetic interference on the ground, since he made a long flight, going both high and far away.
Different from my problem, is also that he didn't get a compass error, no IMU error either.
Anyway, your and his best bet is to try to find the drone ASAP!
I wouldn't look anymore at the place last recorded by the AC. The thing is that at 12m 58s he lost connection from the remote to the AC. Meaning he was too far away to get reception, or getting blocked by trees/interfered by wifi/radio signals coming from the houses below.
Six seconds later, at 13m 04s, the battery is at 19% and this is the last thing transmitted by the drone that he picked up. Nothing about auto landing or critical battery yet. And he is still 139m up!
Checking the log, the AC moves in average ~7 meters per second in the wind, this means that the Spark will have gone a long way from the position, and it will probably followed the straight line it made on the map, seems like the wind direction was concistent.
The manual does not cover what happens when you loose connection while in ATTI-mode, but some users report that it will auto land in 3 seconds. Also, his battery was low, so a auto land could not have been far away, and auto landing will be triggered by this also.
If he is lucky, the AC regained GPS-mode, then it will land steadily. If still in ATTI while landing, it will still go fast in the wind directions, and visual sensors is not working, so then it's high risk of a crash. He might have DJI care though, so finding it is important.
I am not good at calculating wind speeds/distance/descent and give estimates as to where it might have landed, but there are guys at some other forums that are really good at this.
Also, can you please upload the log to https://www.phantomhelp.com/LogViewer/Upload/ it might show more data.
Super hard thing still, but good thing you have a drone and can help him search for it! I would start around here: https://goo.gl/maps/HpX82EezC5aELBtT9 and fly in kind of a straight line, both back and forth.
I wish you the best of luck! |
