Bad analog latency on FPV Goggles
7189 11 2019-8-18
djiuser_PXhfdZkKV90w
Sweden
Have anyone else tried the analog input on the DJI FPV Goggles and noticed really high latency?
This is especially noticable if you are drone racing on a track. I had no problem racing with the digital signal but when I switched to analog on the goggles it was unflyable!
2019-8-18
MarlonI
I'm trying to get hdmi in woking from an analog signal.. Exactly what converter/cable are you using as the analog to hdmi? I have an AV to HDMI converter, it works for my Headplay goggles and my FatShark goggles but not for me DJI FPV goggles.
2019-8-18
GhostFPV
Sweden
MarlonI Posted at 8-18 12:44
I´m talking about the goggles for the DJI Digital FPV System. They only have a input port for analog signal.
Using a Dockking-module with Rapidfire connected to the analog input on the goggles.
2019-8-19
MarlonI
Yes the DJI Digital FPV system goggles.. My first attempt was with a DockKing but apparently the HDMI module I have does not work and I cannot find another Furious FPV HDMI module out there on the web so I tried an Amazon AV to HDMI converter. That works for my Headplay goggles and my FatShark Dom V3 but not for the DJI FPV goggles. But you say even with a DockKing and HDMI module the lag makes it unflyable.   That's a drag cause my goal was to be able to fly my old analog systems with the DJI goggles. Less gear to carry around. I'm gonna test the lag time on the Headplays and FatSharks when they run on HDMI.
2019-8-19
vap
Russia
That's sad news, i was hoping it can work on analog input. Travelling with 2 sets of goggles wouldn't be ideal.
2019-8-19
GhostFPV
Sweden
MarlonI Posted at 8-19 03:09
Sorry I`m confused. But how do you connect a hdmi cable to the goggles? I thought they only had two input ports, analog video and usb. Have I missed the hdmi-port?
2019-8-20
EmilioCid
Flight distance : 7445200 ft
Many people experienced signal issues when connecting DJI Goggles with Mavic.  if you have the goggles, please answear the form
https://docs.google.com/forms/d/ ... Y7vu8zwfGg/viewform
2019-9-11
Charmande
Flight distance : 299459 ft
From what I've seen in test videos this system is not meant to work with analog in that way. Hopefully they can update it in the future but as far as getting great analog latency right now I believe you may be out of luck unfortunately.
2019-9-11
Furadi
From what I've heard this is somewhat dependent on the camera as well. One of my fellow team mates said he had good luck with the runcam racer.
2019-9-15
QuadCatper
Which goggles are you referring to? The RE or the new FPV ones?
2019-9-16
halitic
Latency in AV in for the FPV goggles is still a bit too high. Sometimes even unflyable
So when you're using like a docking module to plug your analog module to the DJI FPV goggle.
If that's a software related issue, that would be great to have fixed (together with the both brightness and saturation box constantly showing)
2019-10-8
famtory
South Korea
Delays range from 35-100, even 160, but change when cycled. If you turn the power off and on, the latency will also change. If you experience severe delays, try turning the power off and on.
2019-10-20
