ajohnson-laird
Flight distance : 124636 ft
I have an Inspire 2 that I bought some time ago but haven't had a chance to fly other than once when I bought it (don't ask, life got in the way).
When I was preparing to fly it last week, I charged four TB50's up, powered up the aircraft with pair #1, and did all the firmware upgrades with the first pair of batteries, but I ran out of time to do the firmware upgrades for the second pair. That started to happen when I got out to the flying field the and installed the second pair of batteries.
I saw the inconsistent firmware versions message, so rushed to set up my iPhone as a hot-spot just in case Internet connectivity was required.
I thought the battery firmware updates had completed, but then I noticed that one of the TB50's had the two center LEDs on solid. Worse yet, I could not power off the Inspire 2 -- it would power off and then power on again. I had to rip the TB50's out to power it off.
I can only surmise (given the fact I've only charged the TB50 once when I got the aircraft and kept it at storage charge since), that the firmware upgrade failed and somehow bricked the TB50. I've tried charging it, but it will not charge -- the charging hub does not even recognize it.
Is there any way of forcing the TB50 to accept a firmware upgrade? (In other vendor's parlance: Is there any way to force the firmware in the TB50 to go into bootloader mode?)
Thanks in advance
Andy
