Samsung Galaxy tab S5e
2197 2 2019-8-18
Wayne Newman
Hi does any know if this tablet will work ok with DJI GO.
Thanx
2019-8-18
DJI Tony
Hi, thanks for the inquiry. The compatible devices can be checked by going to the specific page of your aircraft. However, using a mobile device that is not part of our recommended device doesn't mean that the application would not work. There's a possibility that it may work properly due to the capability of the device but then again, sudden changes in the behavior of the app while using it may change especially if there's firmware or application update. Thank you for understanding.
2019-8-20
Blériot53
Flight distance : 6188465 ft
The S2 works fine with it, so you may be in luck with the later model.
2022-5-21
