Problems after latest App (PC) & S1 Firmware Update?
sevreNniarB
Seems like DJI changed something in the WiFi code. After the recent update (S1 Firmware & PC Software) my "Wired Connection" does not work anymore:
Still can play in Solo Mode, but the video stream is not working - a direct connection via Phone is still working fine. Is there any way to go back to an older Firmware or something like a factory reset? Any help is highly appreciated.
Cheers
2019-8-20
BGA
Just to be sure, did you also update the windows app?
2019-8-20
sevreNniarB
BGA Posted at 8-20 08:08
Yes, also uninstalled & reinstalled it. Same outcome   Checked it on a 2nd machine (my Notebook) still same problem. OS is Windows 10 1903.
2019-8-20
MarkusXL
Ugh, that is a problem.  I assume the firmware update went fine?  The robot rebooted, flashed all the LEDs, the robot voice counted through "10%...90%", right?
Ummm that is a hard one.  I can only suggest try to connect in another location / environment / WiFi / router.   Also cold boot your device, try another device...
My iPad mini last week refused to connect to S1 until I cold - booted it...
And, if all else fails, buy another one, carefully replace the defective module, re-pack and return.
2019-8-21
sevreNniarB
Found the Problem.
Just Installed the old RoboMaster_x64_v1.0.2(260) Version and everything works like a charm. They changed something in 1.0.4 that completely breaks it in my environment.
Cheers
2019-8-21
sevreNniarB
@Mods: Is your tech department aware of this topic?
2019-8-25
Ray..
I have the same problem !!
2019-9-22
MarkusXL
I put the 1.0.2 version in a public read only DropBox:
https://www.dropbox.com/s/yg3c2y ... 2%28260%29.exe?dl=0
You can't regress the firmware, but this old version of the PC App should work. Windows PC Only.
2019-9-22
Ray..
MarkusXL Posted at 9-22 02:44
https://www.dropbox.com/s/yg3c2yjzpt2w39i/1562232499731-RoboMaster_x64_v1.0.2%28260%29.exe?dl=0
Thanks for the link!
2019-9-22
rhoude57 - YUL
sevreNniarB Posted at 8-21 08:25
Found the Problem.
Many have reported issues with the Windows PC program V1.0.4.
The problem is not universal, however. I have been running V1.0.4 since its release with no issues.
I wonder if this could be a firewall issue. In my case, I have taken down all firewalls on my home network and on my TP-Link AC750 RoboMaster router.
2019-9-22
MarkusXL
Mee too, no issues at home - but my corporate Anti-Virus blocks installation on any of my work PC's.  It is detected as a Threat...
2019-9-22
sevreNniarB
Update: The current PC Version 1.07 (1571035732453-RoboMaster_x64_Installer.exe) fixed the problem for me. Now everything is working great: Windows 10 x64 (Build 1903), Wireless connection via router & direct connection.
Thank you DJI
2019-10-14
Ray..
sevreNniarB Posted at 10-14 13:24
Thank you DJI
I updated with newest firmware 1.0.7(321) and was still cannot be connected and finally I got the reason on my experience:
I use a mesh wifi system and I compare the IP address of my PC and that of the Robomaster S1, then I found that they have different subnet mask. This reminded me that the wifi system was doing a role of router, it generate its own IP subnet that the Robomaster cannot reach the PC!
After finding the setting page (I use tp-link AC-1300), I changed the operation mode from Router mode to Base Station mode or Access Point Mode (AP) in other system then, the connection success.
Hope this share useful.
2019-10-18
