"Off" setting for remote controller type?
1251 4 2019-8-20
george_007
Flight distance : 183045 ft
Sweden
Hi team!
I only have one remote and I don't understand if I should have the remote controller type set to "Off" or "Master" in the DJi GO app.
What is the difference between the two when using only one remote?
Regards
Georg
2019-8-20
DJI Tony
Hi, thanks for the inquiry. Usually, the dual remote controllers mode can be used when coaching your friend/relatives when flying the drone. The Slave controller can command the aircraft, as well, however, the access would be limited only as the aircraft would prioritize the command from the Master controller. You may also refer to the screenshot below for further details and the video tutorial.
2019-8-20
george_007
Sweden
Hi Tony!
Nice answer but unfortunately it does not answer my question.
Can you have another look at my original question?
Regards
Georg
2019-10-17
Mark Guille
Flight distance : 2031818 ft
Jersey
george_007 Posted at 10-17 08:14
Hi Tony!
If you have only one remote, set it to master.
Mark G.
2019-10-17
george_007
Sweden
Thank you Mark.
When should you use the "Off" option?
2019-10-17
