fansfe82067d
You'd also need the necessary code from EACH phone manufacturer to hook into their particular way of doing 4K60. How many are there? What is the chance of them releasing their proprietary code? If Filmic Pro can't do it except in a few specific cases, then DJI hasn't much of a hope.
As for needing to use the on-screen record button with native apps instead of the gimbal button, that shouldn't be necessary if the native app has an option, or built in function, to accept volume key as shutter button. I believe most do. Sure that leaves a lot else not working, but as you (or someone) mentioned that particular one, that's the answer.
(The minute someone points out ANY phone gimbal that has 4K60 with all Anddroid phones, I'll shut up!)
