Im planning on using an external microphone for the osmo pocket. ive heard some rumors that using a usb c to 3.5mm jack adapter and plugging in a 3.5mm mic will automatically work when using the osmo pocket. This already sounds a little hard to believe, but I will also be using the smartphone adapter. So that means that not only will i have the dji mimo app open and recording, it also means i dont know where to plug in the mic; the osmo pocket or the smartphone? and this is assuming that it will even work at all. This is the usb c to 3.5mm adapter that I ordered for the osmo pocket (again, assuming if it even works at all. if not, thats money down the drain!)
BobWinNV Posted at 8-20 16:07
That adapter from Amazon will not work.
You will find that only the Official DJI adapter will work and then only with certain microphones.
