Geebax
snowyxsnowy Posted at 8-25 19:11
I'm saying exactly what you repeated so how are you confused? preview feed / transmitted vision, same same. If it's the iphone7Plus decoding causing lag, choppy, footage then why is the saved SD card footage the same... seems like my drones raw vision has some sort of processing error yesterday. hopefully is due to inserting sd card after. If i had any brains at all i would have removed the sd card on the second spot, something to test another time. More testing required before i blame 4.3.24 i suppose...
You cannot record lag. Lag is when the received video is lagging behind the actual video action. And the video saved to the SD card in the aircraft will not be laggy or choppy. Also, if you have your settings for the camera set up to record in 4K, then the recording on the SD card in the aircraft will be in 4K. However the feed to your phone will only be in 720p, as it is only intended to provide you with a rough idea of exposure and framing.
If you are playing back the SD card and it appears to be "choppy", then the problem is with the method you are using to play it back. Firstly, you need to play it back on a reasonably powerful computer, and you need to have a decent video player. Also, you need to copy the file to the HDD on your computer and then play it back, do not play back off the SD card itself, as the SD card reader will slow down the data transfer.
If you would like us to take a look at the file, upload a short un-edited file to Dropbox and someone here can take a look at it.
