DJI Tony
fans966b439c Posted at 8-27 16:41
Hi Tony...thank u very much for the feedback...really appreciate it. So assume i get Samsung S6 or S7 or any other android which is listed, do i have to do anything the OS version? any specific android version required?
Hi, thanks for the prompt reply. You may try a device that is included in our compatible devices to easily isolate the problem. Actually, using different mobile device doesn't mean that the app wouldn't work, there are possibilities that the app would run smoothly using due to the capability of the phone. However, since it hasn't tested by our engineers. the behavior of the app may change especially if there will be application or firmware updated. As of the moment, the DJI Go 4 app is compatible with Android Pie. Hope that this would clarify your query. Thank you for your support. |
