LEONIDAS GREECE
Flight distance : 5270591 ft
Greece
HI, I HAVE A CENDENCE WITH PATCH ANTENNA AND I NEED TO INFORME IF THIS ANTENNA HAS BOTH 2,4 AND 5,8GHZ OR ONLY 2,4?AND IF NOT WHERE IS THE 5,8 GHZ,AND MY OTHER QUESTION IS THE COMUNICATION SIGNAL FROM SLAVE TO MASTER IS RF WITH ANTENNA ON BOARD?BECAUSE THE SIGNAL IS VERY WEAK AND THE IMAGE QUALITY IS NOT GOOD,THE PICTURE HAS PIXELATION, AFTER SOME METERS.IS GOOD IDEA TO PUT THE MULTILINK TO HELPS THIS PROBLEM?THANKS!! |
