silpheedx
Flight distance : 11936 ft
Dragon link is basically a giant, high-latency(slow), version of the DJI FPV sytem. With the DJI FPV system if you want to try long range I would recommend first getting a GPS for your rigg. Then make sure Return to Hom , RTH, works. Then get 4 nice patch antennas like these "TrueRC 5.8GHz X-AIR (LHCP)" for your goggles. Then get 2 tall big antennas for your air unit like these "Lumenier AXII 2 Long Range Right-Angle 5.8GHz Antenna (LHCP)". You will also need the adapters for the air unit "7cm SMA Female to 90 Degree MMCX Male Cable" . With all that you should be able to get reaally far out. BUT Make sure your head is pointed at your drone. Those patch atennas are directional not omni. |
