S-e-ven
Flight distance : 5922034 ft
Thailand
Is it "just" the RTH descend, or have you moved throttle down, too?
I "found out", that at least the "normal" throttle use down is adding speed to the critical battery descend.
Or better, actually worse, a normal stick controlled descend can get into a high speed descend, as soon the battery hits the 10%.
Which is not nice, as soon you are already almost on the ground!
DJI: Is that wanted?
B/c you can really fly the bird into the ground, in case you get surprised by it, 1,5 m over ground! |
