M210 RKT v2 is recieving an "Weak RTK" error when connecting to our local GPS base station. The drone connects via Wifi hotspot via NTRIP. Base station is on our building and works fine with our GPS survey equipement. The M210 is also able to connect the DJI mobile station without any issues.
Not sure if its a compabitliy issue with the NTRIP set up on our base station.
It took a couple of weeks but the solution was to make sure the base station you connect to broadcasts in RTCM format. FYI DJI was zero help. My vendor was able to figure this out.
