Phantom 4 Pro V2.0 is a beast on DroneDeploy
12Next >
3586 40 2019-8-31
AntDX316
Flight distance : 3394731 ft
If you ever need mapping for your business it's so perfect.
2019-8-31
Bashy
Flight distance : 2354357 ft
Not the Mavic 2 Pro then?
2019-8-31
rwynant V1
Flight distance : 4842277 ft
The preference for mapping would be a camera with mechanical shutter.  The bird can fly the map at 30 mph, and never stop for the shot.
The 200 or 600 images are crystal clear...... I think, I don't know that the M2P can do that.
Randy
2019-8-31
AntDX316
Bashy Posted at 8-31 17:10
I haven't tried it yet
2019-9-1
AntDX316
rwynant V1 Posted at 8-31 21:30
It was set at 7mph but still only flew at 4mph.
2019-9-1
Jimis.M
Flight distance : 754705 ft
Cyprus
I am using MAVIC PRO for mapping only because its more portable than P4 Pro. But I believe that they are almost at the same level
2019-9-1
rwynant V1
Flying a 9 mile stretch of coastal rail, and having to do 3D ortho,   each plot being about 48 to 52 acres at 250ft..... you need a bird that goes 30mph to get it all done in a day...1 battery per flight.
For that you need a mechanical shutter.
Click here for a screen shot a 1 flight plan, and an overhead shot.  https://photos.app.goo.gl/3Mmzqjx1ucfReEJJ6
Randy
2019-9-1
Bashy
My mavic reply was tongue in cheek seen as ant was chirping on about the M2P being better than the P4P and then goes and posts this thread
2019-9-1
AntDX316
rwynant V1 Posted at 9-1 18:12
How did you get it to fly at 30mph?
What camera settings were you using?
2019-9-1
AntDX316
Bashy Posted at 9-1 18:39
I said the P4PV2.0 is better for mapping and C4K60.
2019-9-1
rwynant V1
AntDX316 Posted at 9-1 21:05
Camera 4 x 3  wht Bal= sunny   everything else normal
In Drone Deploy if your legs are long enough you can, in Advanced Settings,  set your speed within reason.   If the legs are short you can get 17 to 20mph.   The AC doesn't stop to take a pic and doesn't fly super slow either
Randy
2019-9-2
AntDX316
rwynant V1 Posted at 9-2 07:27
What shutter speed and aperture and ISO?
2019-9-2
Labroides
Flight distance : 9991457 ft
AntDX316 Posted at 9-2 16:01
Anyone with a basic understanding of photography would realise that you use whatever exposure settings are appropriate for your subject and lighting conditions.
What someone used for his project in whatever lighting conditions he had is meaningless to you in a different situation.
You may as well ask what size shoes he wore.
2019-9-2
AntDX316
Labroides Posted at 9-2 18:19
If you fly at 30mph taking photos, if you do not have a high enough shutter speed it would blur.
2019-9-3
Labroides
AntDX316 Posted at 9-3 06:40
Ohh yeah .. Now I understand.
Photography sure is complicated but I learn so much from you.
I hope to be a great drone photographer just like you when I grow up.
2019-9-3
AntDX316
Labroides Posted at 9-3 07:15
I want to know what ...ter speed the people going at 30mph are using.
2019-9-3
Labroides
AntDX316 Posted at 9-3 07:48
They are probably using a shutter speed that gives good exposure and a sharp focused image.
That could be anything depending on the lighting and darkness of their subject matter.
The height they fly at will also be a relevant factor to consider.
2019-9-3
AntDX316
Labroides Posted at 9-3 08:10
I want the exact numbers
2019-9-3
Labroides
AntDX316 Posted at 9-3 14:44
I'm pretty sure he said it was 3.14159.
Otherwise it would have been 6.62607004 × 10-34 m2 kg / s
2019-9-3
AntDX316
Labroides Posted at 9-3 16:46
in shutter speed
2019-9-3
Bashy
Now that made me spit me coffee back into my cup
Ant, its not an easy question to answer, many factors can upset a photos outcome as youve been told, but it also depends on what look you are going for, now, for someone flying at 30mph then i would have to assume that they are shooting a moving object, if so then it too would depend on what image they are going for, if its static subject image  then a higher shutter would be beneficial but, if the image is to be of, lets say a train in motion and you wanted to capture motion blur in the foreground and background, the most obvious higher shutter speed would NOT be better in this case, a lower and good panning, some skill would be involved to get that type of shot for sure but its just an example, ive seen the post shot too, looks cool (if its to be believed), if youre on FB then take a look
https://www.facebook.com/photo.p ... ype=1&theater&ifg=1
https://www.facebook.com/photo.php?fbid=10214991153839738&set=g.1209153282433132&type=1&theater&ifg=1
Some figures on this one
https://www.facebook.com/photo.php?fbid=833322707036548&set=g.1209153282433132&type=1&theater&ifg=1
2019-9-3
Matthew Dobrski
Flight distance : 1831050 ft
Lab, stop it, I'm begging you ...
2019-9-3
AntDX316
I want to know what the experts have used.  I'm not looking for an around the world reason.  I want to know the settings used by the experts.
I know people have mapped with an FPV plane but I haven't seen what the quality looks like.  I assume it's not 100% perfect.  It's probably just easier to rent Google satellites to scan an area w/ enough money.
I mean, it's probably just better to get 4 drones up in the air at the same time for multi-scanning flown by 4 persons of course.
2019-9-3
rwynant V1
ISO 100
Wht Bal:  Sunny
Everything else on the P4Pro set to AUTO
It has a mechanical shutter.  I know I said that already.
Here is 1 image of over 7000 taken that day ...... the bird was going approx 30mph straight down the road with the rail in view.  250ft AGL
https://photos.app.goo.gl/j2owbUTbKaMb31qK9
2019-9-3
Labroides
AntDX316 Posted at 9-3 20:26
Experts use whatever settings are appropriate for the scene they are shooting in the lighting where they are.
Those settings are going to be different for different locations and light conditions.
If you want to use the settings the experts use, then use whatever settings are appropriate for the scene you are shooting.
If you understood basic photography this would all make sense to you.
Here's some free advice:  Whatever you assume is probably not 100% perfect.
2019-9-3
AntDX316
Labroides Posted at 9-3 21:42
Whatever you assume is always extremely vague so you can always remain right.
2019-9-4
AntDX316
rwynant V1 Posted at 9-3 21:00
ISO 100
Wht Bal:  Sunny
I need to try this but what was the shutter speed set to and are you sure it was at 30mph?  You set it to 30mph but on the drone, it could be doing less.  I set 7mph but it says 4mph on the OSD.
Can you pull the metadata from the picture?
2019-9-4
rwynant V1
One bit of info.....in Post# 8   If you didn't notice,  those are Drone Deploy screens.
In the long legs of the flight, she was doing about 28mph.   The speed shown in both those images, is the RTH speed,  which is 20mph.
Drone Deploy configures the camera "in app" and we have no say regarding anything other than setting ISO/4x3/and Wht Bal in GO4 prior to initiating DD.Shutter speed is an UNKNOWN
Randy
2019-9-4
AntDX316
rwynant V1 Posted at 9-4 09:17
That image is really clear for a 28mph shot.  I should be doing this more often then.
Lowering the front overlap for more side makes the full images time lower by a lot.
Switching to 30% front and 80% side from 80% front to 30% side is lower by 20% but I assume the images could come out blurrier due to the speed.
2019-9-4
KlooGee
Flight distance : 16783757 ft
AntDX316 Posted at 9-4 05:59
You can look for yourself in Google Photos that he provided the link to.  In the specific example he provided, the metadata shows:
ƒ/5.6
1/500
8.8mm
ISO100
2019-9-4
AntDX316
KlooGee Posted at 9-4 09:46
ƒ/5.6
Was that taken at 28mph? 1/500??
2019-9-4
Mullheliflier
Flight distance : 12305135 ft
Thanks for posting AntDX316 I have been toying with mapping. Have not been using my Phantom 4 Pro since getting the Mavic 2s.
2019-9-4
KlooGee
AntDX316 Posted at 9-4 09:50
2019-9-4
AntDX316
I will try doing the same settings flying at 28mph manually.
2019-9-4
Labroides
AntDX316 Posted at 9-4 13:31
Even your attempted insults are as lame and ineffective as everything else you post.
He's told you multiple times that the camera sets an appropriate shutter speed automatically, not him.
But you keep asking.
Because you can't ?
Do you know anything at all about photography?
Your arithmetic is as appalling as your writing.
And where did you get 80% 30% from?  That sounds very unlikely as a default setting.
And you think you can get away with 20% side lap?
Crazy.
You've already seen one of his images at 1/500th and commented that it was really clear
You are making assumptions again after I warned you.
You really have no idea what you are doing so don't go making assumptions because you'll be wrong again.
You still don't know how to check it do you?
You've got someone's secret settings and you'll copy them.
At this rate you're going to be a master by Tuesday.
As you've told us, experience is over-rated.
Copying exposure settings is what it's all about.
There's no need to understand anything.
2019-9-4
AntDX316
Labroides Posted at 9-4 14:12
80% front overlap, 30% side overlap and vice versa, dronedeploy
2019-9-4
Labroides
AntDX316 Posted at 9-4 16:03
I can't tell where you are getting that from but DroneDeploy would never suggest 80% 30%.
Set up a basic mission in DD and it has the default values of 65% sidelap and 75% frontlap and a max speed of 34 mph.
20% or 30% is just crazy ... so completely appropriate for you.
2019-9-4
AntDX316
Labroides Posted at 9-4 17:01
I used to do 80% 80% but it comes out crap.  I find 83% 83% to be the minimum w/ the right altitude set.
2019-9-4
Labroides
AntDX316 Posted at 9-4 19:33
You're just babbling, genius.
Nothing you've said makes any sense.
2019-9-4
rwynant V1
As Drone Deploy goes through the check list,  one of the checks is " Configuring Camera"
So as stated here and there,  the shutter is set automatically by the DD app.  Depending on Altitude and overlap, the speed is adjustable......to a point.
Randy
2019-9-6
12Next >
