Which charger do you use?
3810 4 2019-9-1
Canonian
Flight distance : 37740 ft
Croatia
Which charger do you use for charging your OA ?
2019-9-1
DJI Stephen
Hello and good day Canonian. Thank you for reaching out. The charging time for the DJI Osmo Action is 1 hour and 30 minutes and the recommended charger specifications for the DJI Osmo Action is a USB adapter with 5V / 2 A. Thank you.
2019-9-1
ff22
I have tended to plug it into the computer to transfer content and then leave it plugged in to charge.  But I did buy the two battery and charger kit (now if I could find the 3rd party and charger!)
2019-9-1
Canonian
Croatia
DJI Stephen Posted at 9-1 08:46
Hello DJI Stephen,
I wonder if I can charge with iPhone USB adapter with 5V / 1A ?
Any impact on battery if output power is bellow of recommended?
2019-9-2
DJI Stephen
Canonian Posted at 9-2 02:48
Hello DJI Stephen,
Thank you for the reply Canonian. The impact when charging the battery if the output power is bellow 5V / 2A is that the charging time of the said battery will be longer that of charging the battery with the recommended 5V / 2A battery charger. Thank you.
2019-9-2
