Geebax
nightshade1960 Posted at 9-8 01:18
Well just to return my findings, I took the Drone to a location I flew before, it flew fine no restrictions
The last time when I flew it with the restrictions in place was a place with two steel towers , that used to be fire towers, I didn't see some sort of communication dishes on them, I have been recently told that these are now police communication towers so this could have been the problem
I flew to 325 feet high today although the app said that the communication was weak, is this normal ?
"I flew to 325 feet high today although the app said that the communication was weak, is this normal ?"
If you flew 325 feet above yourself, then yes, that is normal. But if you flew 325 feet away from yourself, then it should have been OK. But as your aircraft seems to be a P3 Standard, then yes again, as the Standard has relatively short range, particularly in urban areas.
