S-e-ven
Flight distance : 5922034 ft
Thailand
Denndb Posted at 9-2 05:25
That exactly is the question, would changing manual 2.4 channel work midair in case connection is already lost.
Actually I had such dilema yesterday, I have manually selected ch8, went flying and somewhere on the way back the connection was lost, obviously due to some interference on ch8, because I wasn't able to get stable connection again no matter how close the Spark was (Spark started RTH). In that moment I was thinking to try to manually select some other free 2.4 channel in order to re-establish connection. However I was scared to do that, did not know how Spark will react.
It shouldn't matter, during aRTH it is RTH till you cancel it.
Trying to change channels can, imho, not make anything worse.
But:
You had a connection from the start till RTH
My expectation is, and experience is telling, too:
Soon on the way back it connects again.
At least in auto mode.
And as I wrote, I can just confirm that the spark is trying to switch bands in case of connection losses or disturbances.
But I do assume that the channels will also be auto changed.
I'd say you get a cable and test all options!
