Hi, I received my Ronin-S a couple of days ago. I got it charged, set up the balance, installed the DJI app and connected to the gimbal, and updated the firmware. Everything seems to work fine, but I am not able to turn off the battery grip. The head turns on and off with no problems, but the battery grip does not respond despite following the sequence on the sticker (single press, followed by a press and hold). I have tried different sequence speeds, different hold durations, etc but I have had no change despite repeated attempts. If i leave the battery grip on over night it will turn itself off, but then the only way I can turn it back on is by plugging it into the charger again. Am I missing something?
I also noticed that the green lights will sequentially light up while I charge the battery to indicate the charge level, but remain constantly on (solid) once charged. single pressing the button does not flash the lights to indicate the battery level like I have seen in other videos. The lights will flash while charging and updating firmware, but that's it. Not sure if this has something to do with the issue above?
I have tried long pressing the power button, refreshing the firmware, downgrading the firmware, etc. disconnecting the gimbal head from the battery grip, connecting/disconnecting the gimbal with my PC and connecting/disconnecting the gimbal with the provided charger. I am absolutrely at a loss as to what I need to do next.
Mine does pretty much same. While is on if i press once, will start to blink 3 times and then stays on again. If i keep the button pressed, will blink until i remove my finger. I left it overnight like that and seems like will turn off by itself. Not sure how long stays on but next day morning battery is on same level. I don't consider a big issue and i can live with it.
