David_Harry
Ray-CubeAce Posted at 9-20 22:30
Hi David.
I will check that out. Thanks for the info.
So as far as the rebuild is concerned my PC now consists of the following.
Hi Ray.
Just a few things you may want to bear in mind.
For a few reasons it’s not a good idea to have your OS on any type of RAID for a typical workstation, especially a soft RAID.
Unless your SSDs are of a certain type, again it’s not a good idea to RAID them.
Also, your SATA bus will probably get used completely with just one SSD if it’s a fast one, RAIDing them won’t give you any noticeable performance increase if it’s speed you’re after. If it’s a version of RAID redundancy you’re after, again there are certain issues with that.
If you want redundancy, I’d recommend you simply manually mirror any two drives, SSD or mechanical.
For a simple workstation setup using single drives for everything, boot, storage etc, is the best way to go.
Before using larger capacity fast SSDs I used to have to use either a RAID or a striped set for bandwidth for editing uncompressed video. I could tell you some real horror stories from when I’d had a RAID fail and the parity data couldn’t bring the set back, complete data loss.
In my experience it’s way safer to simply mirror the data or do manual or synced backups if it’s redundancy that’s required. As for speed, a good quality SATA SSD will be enough or a very fast NVMe if you need to work uncompressed ultra high resolutions. I’d also stick with Samsung SSDs. Although their Pro versions are amazing, their Plus versions for NVMe are excellent and cheaper and for SATA you can’t beat their standard EVO 860 range.
You’re mechanical drives will become indispensable for archiving and mid term storage, I’d never get shut of them. I duplicate all my important data to a single large capacity mechanical then back it’s folders to a bunch of lower capacity mechanicals. My SSDs are only used for the OS and active content.
As for your core system, you are going to be like a pig in sh1t when you’ve got it running It’s a fantastic spec for a workstation.
Cheers,
Dave. |
