HH1
Flight distance : 73114 ft
StarRider Posted at 9-9 02:00
HH1, this is exactly my problem. I'm thinking after getting authorization on the phone, downloading it to the drone, then swapping out the phone for the tablet the drone would be able to take off. That is not the case.
There must be some way to accomplish this.
I have done as you described about getting authorization on the phone then downloading to aircraft, then switch to the tablet, and it worked. However, I forget if I got the authorization while the phone was connected to the Aircraft Controller, or connecting the aircraft to the phone and downloading then. After checking on Voice over Internet Protocol, and Voice over LTE, I have come to the conclusion that I can't get the authorization on the Tablet. However, as others here have said the Mini 4 works well for flying the drone, so it is plenty good for areas where you do NOT need authorization. I use it that way in the back yard. Best of luck, I truly know what a headache you are going through. Thanks for texting. Also, does your tablet give the message: "sorry that party has chosen not to receive messages." When you try to text the tablet? Another thing is that when the authorization is sent from Dji, it IS sent by TEXT. I am with you the data part of the tablet and the wi-fi also do a good job, just won't receive TEXT messages or VOICE.
