Horizon problem osmo mobile 3
12Next >
20682 45 2019-9-9
fans9faf160a
Hey
I've just noticed that my horizon is not straight with the osmo mobile 3 that's quite annoying.
Anyone have the isssue ?
Thanks
2019-9-9
Hello there, please check if you selected FPV mode in Gimbel Settings, if yes, please switch to Follow mode to see if the issue persists, thank you.
2019-9-9
DAFlys
On the Osmo 2 there was an option to manually calibrate the gimbal and you could adjust it for level,  have you looked to see if the Mimo app has that ability?
2019-9-10
fans9faf160a
Tried all of this but still the same problem there is no manual calibration within the osmo 3 app
2019-9-13
fans3e4062d1
osmo mobile 3 / just received it today / have the same issue (((((
2019-9-19
djiuser_fREx4wSBI1Gl
Osmo mobile 3 | I have the same problems with the horizon.  Looks very stupid on the videos and photos.
In addition, my phone (Android - S9) is very hot when using the app
2019-9-20
Lowal
Hello. I bought Osmo Mobile 3 too and have the same problem with horizon. Help please!
2019-9-22
djiuser_elDlHeN0HME9
Have the same issue.
First two weeks no issues after two weeks that problem just came out. Unfortunately first two weeks give you the time for the replacement product after that time I can only send it for repair.
Very disappointed. That was my first and the last product from Dji.
2019-9-25
2019-9-25
2019-9-25
VictorL
Same issue and there is no manual calibration on dji Mimo. What I also noticed is it could be due to the phone cover/case. Mounting the bare phone make the situation much better. Moreover, I also notice when I record movie on the move, the horizontal issue will accumulate, and sometimes it tilt left, sometime it tilt right. I have no idea whether it's really an issue for my osmo 3 or it's a common "feature".
2019-9-27
capy01
Flight distance : 8635 ft
I have had this since day one, and nobody seems to have a fix. A slight tilt to left. With or without phone holder and perfectly calibrated.
2019-9-28
Robert E
I’m using an iPhone XS Max and have the same problem. If checking in the level in the measuring app, I’m always -1 or -2 off. It doesn’t sound much but when filming an horizon it sure is noticeable. Of course I can correct it in Final Cut Pro but I’d rather have it useable from the start.
Any good workarounds or suggestions?
2019-10-6
djiuser_vOqUwfM5mBBE
I have the same issue with my S9, apparently you could fix this with the osmo 2 app so why would they remove features for the newer version! It makes it near impossible to make a good pano when it's not level! Please fix now!!
2019-10-10
emerbaum
Flight distance : 64134 ft
Same, Im prob going to return my om3 because of this.
2019-10-10
Didier Swiss
Hello,
Brand new OSMO mobile 3, and the same problem.
Please DJI make a firmware update or app update to be able to fix this
2019-10-12
djiuser_YosAxiBlQ5vD
Hi.
I bought  2  osmo mobile 3.  Both have the same problem with the horizon level.  The app dont  have options  to fix  that.
We need a solutions.
2019-10-12
Didier Swiss
Everyone with this problem, please contact DJI support.
Otherwise nothing will be done
Thanks
2019-10-14
pxchoi
I rushed out to buy mine day one and I'm also experiencing the same issue.
2019-10-15
djiuser_ckAbA0ZF6x6A
Poland
Same here with Huawei Mate 10 Pro. Attached is the perfectly vertical line between wall tiles as seen by Osmo Mobile 3. I've reported it to DJI and waiting for response.
Btw. Horizon line with iPhone 7 is better, but also a little bit off, not exactly what one would expect.
2019-10-18
Poland
Seems like the picture hasn't attached properly.
2019-10-18
13th SQUAD
fans3e4062d1 Posted at 9-19 15:37
[view_image]
UPDATE:
1. Send it back to dji.
2. Received replacement unit (defected as well)
https://youtu.be/aMVX-SzeQLE
3. Send the replacement unit back to DJI again
2019-10-22
13th SQUAD
[view_image]
UPDATE:
1. Send it back to DJI.
4. In the middle of the process I figure out that DJI as a replacement send you a refurbished product - not the brand new. They call it “it’s like a new”....
So in fact Customer paid in full for refurbished product and this is disgraced((((
5. I’ll try to get full refund but DJI representative tell me that it is impossible because of some policy...
So my advice will be the next: if you purchased and received the DJI product which has some kind of defects right from the box - return it and ask for a full refund and never go the replacement option ever.
It is bad DJI (((
2019-10-22
Alonso Garcia
Mexico
You need to turn off the WIFI and if Bluetooth is not active then turn it on, just with no WIFI and it works! At least by now
2019-11-13
Alonso Garcia
Mexico
Alonso Garcia Posted at 11-13 09:45
The easiest way to make it work is to set the phone in airplane mode, then again turn on Bluetooth
2019-11-13
mpetr1960
Flight distance : 4119173 ft
Russia
The same problem.
Very strange!
It is so simple to make manual calibration in programm...
Return it to saler.
2019-11-23
djiuser_VNSCFiY2QZtP
India
DJI Mindy Posted at 9-9 23:57
No i tried it but still I'm finding horizon problem. Please help
2019-11-26
fans5201888e
Flight distance : 168369 ft
Just noticed this on mine too, never noticed it until now unfortunately. It was put away for a while and took it out and ran the calibration, noticed the tilt. Adding manual tilt adjust would be great.
2019-12-3
djiuser_wjErylXMxxCj
Malaysia
FIXED.
I noticed that the top-left corner clamp was pressing down on my phone's power button. So I folded some thick paper together and wedged it between my phone and the soft bumper casing, where the top-RIGHT corner clamp would be. The height of the folded paper would equal the height of the power button. Mounted the phone, powered on, and it works! Perfectly leveled. May not be the most elegant solution, but at least I do not have to buy an "approved compatible DJI phone" to get my footage to be leveled.
Hope this helps.
2019-12-10
Norse Boy
Same problem here. Brand new unit.
2019-12-18
fansc42b9256
My horizon is constantly out of level as well, with no way to adjust manually.   What's worse is that it isn't even consistent, which concerns me that a hardware issue exists for which an app update to allow manual adjustment isn't going to suffice.  Maybe firmware also?
So far very underwhelmed with this gimbal and the Mimo app and DJI Customer support.
I just bought mine, so I might need to return and go with a different gimbal.  An out-of-level horizon is a complete deal breaker.
2019-12-23
djiuser_6zO1JRMuh1Je
Hi all,
I've just bought mine today and I wish I hadn't.
The horizon issue still exists. But my bigger problem is that when filming, it just keeps tilting. It's calibrated well, all straight and holds fine if you don't move it too much. If you start moving it, like closing in on something laying on the floor or the table, and then bring it back up, it doesn't come back up straight, i.e. I keep having to either move to joystick up or down to straighten it, or double clicking the back button to recalibrate back to normal straight. In portrait/landscape mode, the bottom of the phone is tilting towards me(up) when I want it pointing straight down, ie fully vertical.
Don't bother buying it, I'll be returning tomorrow.
2019-12-29
djiuser_RliKAzhptR1w
Mine has the identical problem!!!
I live in Italy and I’ll try to send a video to Dji (even if they know this issue very well).
I don’t understand why not adding a manual balancing just to avoid getting back lots of devices and disappointing customers that are looking for different gimbals.
To better understand my device issue, after balancing iPhone 11Pro Max on a level surface, turn it on, calibrate it, I got -1 level either on the level app and visually on the horizon. Hope DJI will solve it!!!!
2020-1-3
djiuser_fB10HSW5VXOi
Russia
The same problem!
2020-1-3
djiuser_pExtFBrXqwCv
Flight distance : 1093 ft
Same issue. IPhone 8+ in tilt-lock or follow mode. Calibration unsuccessful in correcting this.
2020-1-5
Didier Swiss
Switzerland
I've contacted the support once again.. and still....."can you send me video, what is the firmware"...... It seem DJI DO NOT take this issue seriously. I gave them 2 weeks to solve the problem.  Then we will have to make a Class Action to force them to solve this bug
2020-1-7
Didier Swiss
Switzerland
MIRACLE !!!!!!!!!!!! They have finally updated the Ios App, we can now manually correct the axis....... CONGRATULATIONS DJI, 4 months  to solve this.... ;-)
2020-1-10
PiperD
I too contacted support about this issue. They were useless. They're not even aware that this issue has been resolved with an update to the app or firmware.
It is now resolved, as Didier Swiss noted above. There is now a Horizontal Gimbal Adjustment menu item on the gimbal menu in the Mimo app (I use iOS - don't know if the Android app has this feature). You can incrementally adjust the horizon. My rig is now level. Unfortunately, the update didn't come out until after I returned from a cruise with lots of horizon shots. Grrrrrr....
But, all is well and I'm enjoying the device now. I'm loving the features of the gimbal and the Mimo app, and I'm getting some spectacular video, panorama and hyperlapse shots.
2020-1-26
PiperD
fans9faf160a Posted at 2019-9-13 07:10
There is now. Update your app and firmware.
Gimbal menu, scroll down to horizontal gimbal adjustment. You can incrementally correct any tilt from horizontal.
2020-1-26
bignathan88
Flight distance : 86621 ft
Same issue, for me. I solved using the manual adjustment but honestly I'm not satisfied. Isn't there a way to solve it definetely?
2020-3-24
12Next >
