Waterstrider 2.0
12Next >
2459 43 2019-9-10
RedHotPoker
Flight distance : 165105 ft
Has anyone here boughten the waterstrider... I see a drone shop in Calgary Alberta carry this.
WaterStrider 2.0 Standard
Safely land your drone on water and rough terrain with WaterStrider from DroneRafts.
Engineered to fit the DJI Phantom 3 (all) and DJI Phantom 4 (std), WaterStrider clips on quickly and easily. Its lightweight design has minimal impact on flight times, while the wide pod structure provides an unobstructed camera view.
Featuring QuickDeploy detachable landing gear, assemble and install out of the box in less than a minute.
Leave the CameraGuard base installed on your drone as a gimbal guard and attach the QuickDeploy legs when needed.
Robust design and premium materials are just some of the reasons why drone enthusiasts choose WaterStrider.
RedHotPoker
2019-9-10
DJI Stephen
Hello and good day RedHotPoker. Thank you for reaching out and for sharing this accessory for the DJI Phantom 3 series and for the DJI Phantom 4. Nice find RedHotPoker and in addition just a friendly reminder that DJI do not recommend using 3rd part accessories when operating your DJI drones. Actually, there is a  possibility that this accessory will be able to work with the said drone, however, since it's not yet tested by DJI for the said drone we cannot guaranteed the stability of the  if it will work all the time while using the specific accessory. Thank you.
2019-9-10
RedHotPoker
DJI Stephen Posted at 9-10 12:41
But will it float? ;-)
RedHotPoker
2019-9-10
DJI Stephen
RedHotPoker Posted at 9-10 12:50
Thank you for the additional information RedHotPoker. It is great to know it floats. .
2019-9-10
RedHotPoker
DJI Stephen Posted at 9-10 13:53
That would be the only advantage, for me, for this addition to a drone.
Safe water landings and or accidental forced landing, running out of power above water.
RedHotPoker
2019-9-10
Labroides
Flight distance : 9991457 ft
RedHotPoker Posted at 9-10 13:57
It looks great for Safe water landings and or accidental forced landing, running out of power above water ... when your drone has been blown away because of the windage of that ridiculous (and expensive) contraption.
Should be good for reducing flight times with weight and wind resistance as well as slowing your speed.
Unless you really need to land on water (does anyone?) it's the perfect solution to a problem that doesn't exist.
And more likely to contribute to the loss of your drone than save it.
2019-9-10
RedHotPoker
Labroides Posted at 9-10 14:42
Ok Labroides you’ve now surely convinced me, to buy set. Hahaha
Or, a cheaper solution, avoid flying over water all together... ;-)
RedHotPoker
2019-9-10
Labroides
RedHotPoker Posted at 9-10 14:50
Ok Geoff, you’ve now surely convinced me, to buy set. Hahaha
OK Gerry ..
Or a more practical solution is to realise that flying over water has the same (very low) risk level as flying over water and forget strapping cumbersome contraptions to the drone that only handicap it's ability to fly properly.
2019-9-10
RedHotPoker
Whoops, sorry, my bad. I was temporarily distracted by a local drug bust news piece.
I corrected my error. Once again, my apology.
RedHotPoker
2019-9-10
RedHotPoker
Labroides Posted at 9-10 16:03
OK Labroides...
I shall keep those wise thoughts in mind, particularly while flying low. Hahaha
RedHotPoker
2019-9-10
Montfrooij
Flight distance : 2560453 ft
Not sure if I would land on water.....
2019-9-11
maddox
Interesting! but I still not brave enough to land on water even though if I get it
2019-9-11
1Eagle
Flight distance : 290348 ft
Looks to me like if you did anything but a perfectly vertical landing the feet would catch an edge and....
flip flop, little birdie does a face flop
2019-9-11
RedHotPoker
1Eagle Posted at 9-11 07:25
Hopefully the legs are flexible and allow for some irregular landing surfaces.
RedHotPoker
2019-9-11
RedHotPoker
Montfrooij Posted at 9-11 05:29
That’s what they are built for, safe water landings.
RedHotPoker
2019-9-11
RedHotPoker
maddox Posted at 9-11 06:48
It’s something to be experimented with, in the hot tub. Hahaha
RedHotPoker
2019-9-11
RedHotPoker
Looks safe enough to me.
Light and nimble.
RedHotPoker
2019-9-11
RedHotPoker
Looks great.
RedHotPoker
2019-9-11
Montfrooij
RedHotPoker Posted at 9-11 09:46
I know, but still....
2019-9-12
RedHotPoker
Montfrooij Posted at 9-12 06:40
Yes, still waters run deep.
RedHotPoker
2019-9-12
Montfrooij
RedHotPoker Posted at 9-12 11:12
Too much budget at stake.
2019-9-12
RedHotPoker
Montfrooij Posted at 9-12 12:21
That’s why I’d rather take a floater, for those iffy moments.
But once it lands safely on the water, then what? I can’t swim very far.
RedHotPoker
2019-9-12
Montfrooij
RedHotPoker Posted at 9-12 12:46
Exactly....
I do wonder how they have impact on the flight performance....
2019-9-12
RedHotPoker
Montfrooij Posted at 9-12 12:48
Exactly....
I don’t know, but they wouldn’t be used for extended flights.
No, only intermittent missions above the local fishing hole. ;-)
And other planned excursions whee they may come in handy.
But no long distant or speed flights.
RedHotPoker
2019-9-12
Montfrooij
RedHotPoker Posted at 9-12 21:34
I din’t know, but they wouldn’t be used for extended flights.
I will skip them anyway.
Hope DJI will release a waterproof drone that can be submerged even (while functioning)
2019-9-12
RedHotPoker
Montfrooij Posted at 9-12 22:13
I doubt they will ever offer waterproof motors.
So that is another pipe dream.
RedHotPoker
2019-9-12
Montfrooij
RedHotPoker Posted at 9-12 22:51
There are drones on the market that have just that.
2019-9-13
jacksonnai
Cool! Looks reliable form the video, nice find. Thanks for sharing
2019-9-13
Sean-newbie
Flight distance : 15997 ft
2019-9-13
RedHotPoker
Montfrooij Posted at 9-13 00:41
At what price point to graduate to submariner drones?
RedHotPoker
2019-9-13
RedHotPoker
jacksonnai Posted at 9-13 06:40
Yes, safe and exciting.
RedHotPoker
2019-9-13
RedHotPoker
Sean-newbie Posted at 9-13 07:45
https://www.youtube.com/watch?v=FC9EJhs0pc0
As mentioned earlier, check the price tag, for higher quality drones.
Sure you can water proof nearly anything. But at a cost, that may be prohibitive to most of us.
Though spending thousands on one man helicopter is frivolous spending too.
RedHotPoker
2019-9-13
Sean-newbie
I thought you'd enjoy it, that's all.
2019-9-13
RedHotPoker
Sean-newbie Posted at 9-13 12:35
Oh, I enjoyed it. But I’ve seen these before.
Check the price tag, then make up your mind to order one. Haha
Many here, struggled to put together enough money to buy their DJI model.
Imagine how long it would take an individual, to save, that can’t get a business tax right off
RedHotPoker
2019-9-13
Montfrooij
RedHotPoker Posted at 9-13 12:14
That totally depends on the specs and performance
2019-9-15
RedHotPoker
Montfrooij Posted at 9-15 11:50
We don’t do cheap purchases, or knock offs.
RedHotPoker
2019-9-15
Montfrooij
RedHotPoker Posted at 9-15 13:34
Hahahahahaha.
We support DJI
2019-9-16
RedHotPoker
Montfrooij Posted at 9-16 00:07
Hahahahahaha.
We support DJI
Yes, first class all the way, to 400ft. Hahaha
RedHotPoker
2019-9-16
A J
Flight distance : 13877205 ft
Cool looking device
2019-9-19
RedHotPoker
A J Posted at 9-19 03:19
Cool looking device
Yup!
Sure is. Mr you likes it?
RedHotPoker
2019-9-19
12Next >
