Ronin SC & Panasonic G-85
2370 11 2019-9-11
theblacktechie
Greetings,
I've seen some YouTube videos with Pansonic G5's and other Panasonic models that are compatible with the Ronin SC.
Has anyone got it to successfully to work with the G85? I'm curious.
2019-9-11
M2Wair
Flight distance : 1192231 ft
Yes, it works fine, no issues whatsoever, so far.
Had more issues with the gh5s and a7iii so they will stay on the Ronin S an d M
2019-9-11
DJI Tony
Hi, thanks for the inquiry. We're hoping that you could get the recommendation that you may need with regard to this matter. You may refer to the screenshot for the Panasonic compatible with Ronin-SC. Thank you for y our support.
2019-9-11
jeffchap
How about the G95?  Anyone using the SC with it?
2019-9-12
jeffchap
jeffchap Posted at 9-12 08:20
I ordered a Panasonic cable off Amazon. I will report my findings in a few days on the G95 compatibility.
2019-9-14
Vathemankan
Before the latest update, I had issues with this combo. But not anymore, it works like a charm so far. I think they need to update the compatibility list. Get the Panasonic cable and have fun..
2019-9-14
jeffchap
Vathemankan Posted at 9-14 23:34
Thank you!
2019-9-15
JannisG
How about the G7 / G70? I saw there is a seperate Panasonic cable which I would have to buy but does it work then? (Start stop recording, take photos, (timelapse/panorama function) and focus if half pressed?
Focus wont work obviously but I would buy the pro version I guess.
2019-9-15
M2Wair
JannisG Posted at 9-15 02:08
The G7 is light weight but works.
2019-9-15
djiuser_NdBWliRKrhpq
jeffchap Posted at 9-14 03:11
Hi did you get the Ronin SC working with your g95? Thanks
2019-9-29
fans5a2268b0
Japan
Hello
I just got my ronin SC and my camera is Lumix gx85 are these two working with each other or not ? Cause I dont know how to connect them
2020-4-30
M2Wair
fans5a2268b0 Posted at 4-30 09:16
Hello
You will need to activate the camera manually as the GX85 doesnt have the option to connect to the ronin.
However the ronin will do its job in regards to stability as long as you've balanced correctly.
2020-4-30
