Roll drifting and come back level
740 10 2019-9-12
Gael
Flight distance : 15449035 ft
Hi, i have an issue with th replacement DJI care reresh Mavic pro 2, the roll drift when i fly left or right and come level if i stop.
Try all the calibrations on level surface. What can i do ?
2019-9-12
hallmark007
Flight distance : 9827923 ft
Have you tried to calibrate RC ?
2019-9-12
Gael
i have a smart controller. if it was a tilt issue I understand but why for the roll and horizon ?
2019-9-12
Gael
i am going to do a calibration in a cold environnement to see if it improve that...
2019-9-12
hallmark007
Gael Posted at 9-12 11:41
If your craft is continuing to roll or move and won’t stop until you move stick to stop, it’s likely that RC is continuing to send some signal, this would bo solved by calibration of RC, it’s no different with SRC .
2019-9-12
DJI Gamora
Hi, thank you for reaching out and we're sorry for the inconvenience caused. You can try to calibrate your RC as hallmark suggested in post #5 to see if there would be some difference. Also, can you please try to check the firmware of your Mavic 2 Pro using the DJI Assistant 2 if you have updated firmware. Please keep us posted. Thank you for your kind and understanding.
2019-9-12
Gael
I was talking about the gimbal not the drone.
2019-9-12
Gael
2019-9-12
hallmark007
Gael Posted at 9-12 12:43
Are you in fpv or follow mode
2019-9-12
hallmark007
2019-9-12
Solo1
Flight distance : 383238 ft
Good luck. Had the exact same issue and getting help was hell. Fortunately I was within my window to make a return. I repurchased and the replacement is perfect.
2019-9-13
