_danilo
Flight distance : 275646 ft
You've got some points there, but as I said, it's easier for some people, you included, for some other it isn't.
Drone is burning your battery longevity cycles energized
This is probably the most valid point you have made here!
As for the others:
- card slot on MA is not friendly at all, at least not without modifications (tape)
- I use Linux mostly
- I need SD adapter if I'm downloading on laptop and dedicated card reader if I'm downloading on PC...or I just connect to cable and power on the aircraft, no tedious card removal process |
