New Mavic 2 Pro/Zoom Firmware Released (2019.09.16)
12345Next >
50471 191 2019-9-16
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2019.09.16
  • Aircraft Firmware: v01.00.0510
  • DJI GO 4 App iOS: v4.3.24
  • DJI GO 4 App Android: v4.3.24
What’s New?
  • Added battery mounting detection. Aircraft is unable to take off if the Intelligent Flight Battery is not mounted correctly. Note that DJI GO 4 v4.3.24 or later is required.
  • Added altitude display to video captions.
  • Optimized auto discharging function for the Intelligent Flight Battery. Added ability to set when auto discharge will begin. The default setting is five days. Note that DJI GO 4 v4.3.24 or later is required.
  • Improved obstacle detection accuracy.
  • Improved accuracy of altitude for Exif photos.
  • Optimized Waypoints.
Notes:
  • Restart the aircraft and remote controller after the update is complete.
  • Note that the update may reset various main controller settings, such as the RTH altitude and the maximum flight distance, to default settings. Before updating, take note of your preferred DJI GO 4 settings, and readjust them after the update.
  • If the update fails, restart aircraft, remote controller, and DJI GO 4 or DJI Assistant 2 for Mavic, and retry.
2019-9-16
DarthSLR
Flight distance : 1846716 ft
Yay! Thanks!
2019-9-16
fans8b803c8d
Flight distance : 55305 ft
This looks like a worthy and welcome firmware update DJI, thanks.
However, it's unavailable to those of us who use the Smart Controller since it requires the GO4 app ver. 4.3.24 and the Smart Controller still uses ver. 4.3.16 and there appears (as of this writing) there is still no update for this.
Can DJI kindly advise when the Smart Controller GO4 app will be updated so that the M2 firmware update will be available for Smart Controller users?
2019-9-16
Indio
Flight distance : 303373 ft
no DJI GO 4 Appv4.3.24 for SC?
2019-9-16
DanielVieira
Flight distance : 4633533 ft
No love for SC users....
2019-9-16
Oracle Miata
Flight distance : 3759829 ft
DanielVieira Posted at 9-16 07:04
Battery fix you say.  Hmmmm...
2019-9-16
Oracle Miata
Crystal sky users can tell you all about those blues...
2019-9-16
djiuser_Fup3D6vIBRZm
Flight distance : 17110 ft
Battery fix? What do you mean by that?
2019-9-16
But yes, would be great to know when the smart controller receives this new update... I'm on.21 with the go4 app on the SC
2019-9-16
Archangel3356
Flight distance : 4655896 ft
Oracle Miata Posted at 9-16 07:08
Why yes, yes we can. Good luck
2019-9-16
DanielVieira
Yeah i know what...
2019-9-16
SupCarlos
Flight distance : 1454193 ft
can someone explain these two bullets?
2019-9-16
Roger1167
Flight distance : 1510728 ft
Thanks DJI for new update.
2019-9-16
Northwood
Flight distance : 2148596 ft
More details about the battery improvements(?) please.  Does this address the root cause of swelling batteries?
2019-9-16
HereForTheBeer
Flight distance : 5381368 ft
sadly this will likely be the final software update for the mavic 2 series so looks like dji won't be going for enabling side sensors in any form while in position mode flights even though in theory it would be possible  and could prevent stupid little crashes nor adding digital zoom which requires almost no hardware to utilize and has been added to phones and devices decades ago.
maybe once skydio comes out with next gen device and if they can undercut mavic 2 series in cost and integrate all their avoidance and AI systems it may re-inspire DJI to take their mavic 2 functionality further, upgrading active track software/AI, enabling dif sensor modes, adding digital zoom functionality, etc etc.
2019-9-16
Why should this be the last update!?
2019-9-16
Wiruz
Flight distance : 300548 ft
Is this the best DJI can do since April? Well i can say i will jump over this one as i cant see anything useful before i see the report from other people.
I think DJI is more into blocking firmware downgrade then fixing the actual drone itself .Big thumb down!
2019-9-16
Oracle Miata
Waypoints are fixed.  Smooth transitions are go.  Nice job.
2019-9-16
Paulo Lobo
Flight distance : 12044 ft
I didnt test it, but for you all, this dji upgrade on firmware was asked by manny people, we been waiting for this for about one year !
So yeah ! Good Work DJI Team, Good Work DJI Engineers ! We know its not been easy to repair the bugs special on gps EXIF fotos !!!
THANKS A LOT DJI !!
2019-9-16
Ecuaman
After updating the firmware I have no video transmission??? Using the Smart controller.
__Rolled back to previous version and now it works. I presume that the Smart Controller software must be updated to???
2019-9-16
djiuser_pckoURbgFjVr
please update 4k 50p
2019-9-16
SFC
Flight distance : 10322858 ft
No update for the Smart Controller users yet?
2019-9-16
fans8b803c8d
Can DJI please advise on this aircraft firmware update v01.00.0510 with regard to Smart Controller users? The update is available for my M2P but two of the key battery features are not available to the GO4 app ver. 4.3.16 currently installed on the Smart Controller and there is no indication of an update to ver. 4.3.24 which is required for the battery mounting safety detetection and the new discharge feature.
Is it okay to proceed and update the aircraft firmware anyway?
Also, when will the GO4 app ver. 4.3.24 be available for the Smart Controller to enable use of these new aircraft battery safety and maintenance updates?
(I have already had to replace two swollen batteries for the M2P with possibly a third instance developing, all manufactured before Aug 2018, hence my interest in these new features.)
2019-9-16
HereForTheBeer
so...interestingly i started pulling apart this update... well when i say i did my friend did some pulling apart and this appears to be a "completely new branch update."  but version numbers dont indicate its a different branch as it has same prefixing.   sooo..ya  not even sure wtf that means.
2019-9-16
sjd666
Flight distance : 3785020 ft
Lucky you don’t have a CrystalSky as your never get an update.
2019-9-16
AIRQUAD
Flight distance : 25751486 ft
Updated both Mavic and remote control everything seems to work fine after a test flight I just did.
Thanks DJI
2019-9-16
AntDX316
Flight distance : 3394731 ft
Do you have to recalibrate the IMU after an update?  Also, was there a "battery" update?
Is there also a standard controller update?
2019-9-16
AIRQUAD
AntDX316 Posted at 9-16 23:04
No i didn't need to do any calibrations and there were no battery updates, just Mavic and remote
2019-9-16
AntDX316
AIRQUAD Posted at 9-16 23:16
Standard Remote upgrade?
2019-9-16
fans8b803c8d
DJI moderators, can you please advise when the Smart Controller GO4 app will be updated to take advantage of the very useful battery features in this firmware update? Currently I am on GO4 ver 4.3.16 and this M2 firmware update requires ver 4.3.24 for all features to be enabled.
Seems like Smart Controller users are ignored when it comes to GO4 app updates, same as Crystal Sky owners and the main reason I didn't purchase a Crystal Sky monitor for the Inspire 2.
2019-9-16
AIRQUAD
AntDX316 Posted at 9-16 23:32
Yes standard remote
2019-9-16
AntDX316
2019-9-16
YES, there are BATTERY updates as well!
If you got more than 1 battery, plug them in one by one and you get the update prompt!
2019-9-17
AIRQUAD
djiuser_Fup3D6vIBRZm Posted at 9-17 00:01
Have tested 2 batteries already, but will try again
2019-9-17
AntDX316
I will just do it on the field.
2019-9-17
AIRQUAD
Thanks, now I also received notification of battery update, but not before when I did the other updates
2019-9-17
AntDX316 Posted at 9-17 00:06
Waste of time in the field, but OK
2019-9-17
AntDX316
djiuser_Fup3D6vIBRZm Posted at 9-17 00:27
Sometimes I get a battery firmware update even after many flights anyway.
2019-9-17
OK, that's strange. But doesn't matter, there are updates, so we install them
Just the expensive smart controller and crystal sky get nothing.
2019-9-17
DAFlys
DJI,  thanks for fixing the waypoints but is anything new coming soon?
2019-9-17
12345Next >
