NEW P4RTK FIRMWARE announced in Pro Systems Forum
6229 33 2019-9-16
patiam
Flight distance : 1118740 ft
New FW was released today for the P4RTK/D-RTK 2 but for some reason DJI only posted the announcement in the Pro Systems Forum. Looks like we might be getting "mode 3" and some other improvements finally!
Overview:
  • Date: 2019.09.16
  • Aircraft Firmware: v02.02.0011
  • Remote Controller Firmware: Phantom 4 RTK Remote Controller: v02.02.0014
  • Phantom 4 RTK (SDK) Remote Controller: v02.02.0011
  • D-RTK 2 Mobile Station Firmware: v02.02.0012
  • DJI GS RTK App: v2.1.0
  • DJI Assistant 2 For Phantom: v2.0.7
  • DJI Assistant 2 For MG: v2.0.13
What’s New?
  • Added a Block Segmentation function to divide large mapping areas into multiple missions that can be executed using single aircraft or multi aircraft in Multi-Aircraft Control mode.
  • Added altitude optimization for orthogonal operations. When enabled in the app, the aircraft will fly to the center of the operation area to collect a set of oblique images after the flight to optimize the altitude accuracy.
  • Added multiple flight modes (for Japan only). When enabled in the aircraft settings in the app, users can switch the flight mode using the flight mode switch on the remote controller. The P and F positions on the remote controller are for P-mode, and the A position is for A-mode.
  • D-RTK 2 High Precision GNSS Mobile Station can now be used as an RTK rover.
  • Added Cloud PPK Service to provide high precision positioning computation (for Europe only, Russia excluded). Users can upload satellite observations files and raw PPK files to the cloud server for post processing and view the results of the PPK calculation.
  • Added aircraft altitude comparison in Multi-Aircraft Control mode to optimize obstacle sensing among multiple aircraft. When the altitude difference between aircraft is more than 5 m, criss-cross flight is supported.
  • Added a data copy function to the D-RTK 2 Mobile Station. Connect the D-RTK 2 Mobile Station to the computer to copy the PPK data directly.
  • Optimized Waypoint operations. When RTK is enabled and it is working properly, users can choose to perform missions using an absolute altitude. Users can select between absolute altitude and relative altitude when starting the mission.
  • Optimized UI for Terrain Awareness mode.
  • Adjusted the restricted zones for country borders to improve the accuracy of the flight limits.
  • Fixed the issue where the Network RTK was unstable in some regions when using a Huawei dongle.
  • Fixed the issue where new firmware could not be downloaded in the DJI GS RTK app. When using an old version of the app, this issue can be fixed by: going to the main screen, tapping Menu, then Settings, Apply to All, Explorer, Internal Memory, and entering the path DJI\firm to delete the old firmware file.
Notes:
  • After updating this firmware for the Phantom 4 RTK Remote Controller, the remote controller can only be used with the Phantom 4 RTK aircraft.
  • The firmware for the Phantom 4 RTK Remote Controller and D-RTK 2 Mobile Station can only be updated using the DJI GS RTK app.
  • Make sure that the firmware for the aircraft, remote controller and D-RTK 2 Mobile Station is all up-to-date. Otherwise, they will not work together.
  • Using this firmware with a version of DJI Terra older than v1.2.0. is not recommended, as some functions will not work properly.
2019-9-16
Vorlauf
Thanks Patiam! Updating now.
2019-9-16
DJI Stephen
Hello and good day patiam. Thank you for sharing this information and for sharing this update with us. Thank you for your valued support.
2019-9-16
nota1980
I can't update the RC. He gives me the following message: up to 3 firmware can be dowlond. please return to the list page and deleted unwanted.
I go back to the firmware list and only the current one appears, and it doesn't let me delete it. How can I install it?
2019-9-16
Vorlauf
nota1980 Posted at 9-16 22:21
Make sure the drone is turned off when trying to update the controller.
2019-9-17
DJI4Survey
Flight distance : 6484478 ft
Updating now.... Looks to be some really good additions.  Hopefully there is some documentation to come along with them.
Was anyone at Intergeo ?  Any insight given when this stuff was announced?
2019-9-17
DJI4Survey
Wonder how long until the firmware is available through DJI Assistant.  Hit and miss downloading through the app at the moment.
2019-9-17
DJI4Survey
"Added altitude optimization for orthogonal operations. When enabled in the app, the aircraft will fly to the center of the operation area to collect a set of oblique images after the flight to optimize the altitude accuracy."
Could this be DJI's solution to the focal length issue at varying heights......................so much hope.
2019-9-17
patiam
DJI4Survey Posted at 9-17 15:46
Guess we'll see...
Agreed, there's a lot of promise(s) in this update!
2019-9-17
jivago
Flight distance : 23671 ft
https://www.dji.com/mobile/phantom-4-rtk/info#downloads
2019-9-19
choppedxs
Flight distance : 602090 ft
So I ran the update. What a pain! The RC update is soooo slow now that you have to use the app to update. The drone updates through DJI Ass 2 fine. As far as the base is concerned there seems to be no way to update via app so tried through DJIA2. This works but the latest version is 12 not 14 as in the release notes. Is the this a typo or has someone figured out how to update to 14 via the app somehow?
2019-9-23
Nebuchadnezzar
Flight distance : 3462946 ft
News for Rtk Users
2019-9-24
DJI4Survey
Multispectral - Well that came out of the blue!  Built in sun reflectance sensor is massive if it works!  Going to airworks next year, hate getting this stuff without any context.
Cheers Nebuchadnezzar
2019-9-24
choppedxs
DJI4Survey Posted at 9-24 15:22
So can anyone  confirm if the base staion is running software version 12 or 14? Someone out there must have done the update
2019-9-24
choppedxs
I tried terrain mode and while its nice to see the DEM it would be nicer if we could also turn it off and on as otherwise you can no longer see the image underneath. Maybe I am missing a setting somewhere to turn this opaque or off somewhere
2019-9-24
John Simmons
Is there a trick to getting this update to upload?  I have tried numerous times and it has failed every time.  Updated my DJI assistant 2 and it connects fine.  Gets to 99% then fails.
2019-10-2
choppedxs
choppedxs Posted at 9-24 18:20
To quote Pink Floyd "is there anybody out there?". Can anyone confirm the latest firmware version for DRTK2. The release notes say 14 but when you update it is 12.
Anyone??
2019-10-2
DJI4Survey
I am using 12 and am having no issues.
I do not have the option to upgrade to 14 through DJI Assistant 2 yet.
2019-10-2
LYVFD8142
Did you ever get past this?
This happened to me and I had to connect to the RC via a USB connection and go into the directory and remove old firmwares, I created a Old Firmware directory in the root and just moved them in there. Once that was done I was able to get around the "up to 3 firmware can be dowlond. please return to the list page and deleted unwanted."
2019-10-7
SkySite
Flight distance : 3757 ft
"Added altitude optimization for orthogonal operations. When enabled in the app, the aircraft will fly to the center of the operation area to collect a set of oblique images after the flight to optimize the altitude accuracy." Anyone get any results from this?
2019-10-7
mamas_n
SkySite Posted at 10-7 05:38
It says when enabled in the app, I haven't found anywhere that option. Anyone knows where to enable it?
2019-10-7
LYVFD8142
This Firmware version still didn't fix the DJI Terra Home Point issue for those using Terra
2019-10-7
DJI4Survey
mamas_n Posted at 10-7 05:52
Hey Mamas,
It is a toggle button when doing your flight planning.
If you are not seeing it, make sure the RC firmware upgrade has worked.
Cheers
2019-10-7
mamas_n
DJI4Survey Posted at 10-7 22:44
Hey Mamas,
Ok thanks found it, I always fly 3d planning so I didn't see it. The toggle is only available for 2d planning.
2019-10-9
mbuonanno
Hi there,
last week I was able to upgrade the D-RTK2 Mobile Station Firmware from version v02.02.0012 to v02.02.0014. In the next days I will test the new features described in the "PHANTOM 4 RTK Release Notes" document. ( https://dl.djicdn.com/downloads/ ... tes_en_20190916.pdf )
I did the firmware upgrade using the DJI GS RTK app, because DJI Assistant 2 (v.2.0.8) is only able to upgrade up to v02.02.0012.
The procedure to follow is the same (with the appropriate changes) to upgrade the firmware of the aircraft and of the remote controller described into the "Phantom_4_RTK_User_Manual_v1.4__EN" (page 68 - Upgrading the Firmware).
1. Power on the remote controller and the D-RTK2. Ensure that the remote controller has access to the Internet.
2. Connect the USB-C port on the remote controller to the USB-C port on the D-RTK2 via a USB-C OTG cable and a USB-to-USB-C cable.
3. There will be a prompt (Device Firmware) on the lower right corner in the DJI GS RTK app if there is new firmware. Tap the text to enter firmware page.
4. Tap the Check button.
5. Under "D-RTK 2 Mobile Station" tap Update to enter firmware information page and follow instructions to download and install the update.
6. After successfully completing the update, restart the remote controller and and the D-RTK2 manually.
Good upgrade to everybody !
Maurizio
2019-11-4
myke
Flight distance : 37244 ft
Indonesia
The base station software is actually Mobile Station: 02.02.0014 and if you dont get that onto your base things dont work.
2019-11-4
mbuonanno
myke@enmintech.com Posted at 11-4 06:00
Hi Myke,
do you mean that the installed firmware must be v.02.02.0014 both on the P4RTK Remote Controller and the D-RTK 2 Mobile Station ?
At present the configuration of our P4RTK system is:
•Aircraft Firmware: v02.02.0011
•Remote Controller Firmware: Phantom 4 RTK Remote Controller: v02.02.0014
•D-RTK 2 Mobile Station Firmware: v02.02.0014
•DJI GS RTK App: v2.1.1
•DJI Assistant 2 For Phantom: v2.0.8
2019-11-4
DJI4Survey
Indonesia
Are you guys still constantly getting firmware warnings due to Aircraft not matching RC firmware version?
It annoys me (cannot use the actual language in the forum) and DJI need to sort it out.
2019-11-14
dodger_rog
One of the points in the release notes for this upgrade says "Optimized UI for Terrain Awareness mode."
I haven't upgraded the firmware as yet, but was wondering for those that have, what has changed in the Terrain Awareness Mode?
Have DJI added the ability to import KMLs over the top of DSMs?
Also, has anyone used the Block Segmentation function?
Keen to hear any thoughts/comments before I install...
2019-11-26
DJI4Survey
Hey Dodger,
You cannot import KMLs over the top of DSMs, but you can now draw boundaries onto the elevation model.  You can, kinda, use the elevation model as a base map. Although depending on the height variance in your surface it can be hard to navigate.
The actual terrain model functionality is not super intelligent and working in the mining environment with shear faces, it scares the pants off me.  So we have shelved it until it is refined a bit more.
Block Segmentation we haven't touched.
2019-11-26
dodger_rog
DJI4Survey Posted at 11-26 19:17
Hey Dodger,
Thanks DJI4Survey.
I was hoping that they had added this functionality. I do have a bit of a clunky workaround which involves importing a kml into the standard 2D mapping mode, taking a screenshot of each of the corners of the polygon and then matching those corners when I manually input the survey area in the Terrain Awareness mode.
I'm not sure having the DSM visible would be an advantage for me (other than knowing that the elevation data has been imported correctly). Do you know whether you can turn off the visibility of the DSM so that you can see the map imagery underneath?
2019-11-27
IRDAC
DR Congo
J'ai un drone P4RTK avec sa base station D-RTK 2. Svp, quelqu'un dans ce forum peut-il m'aider à savoir comment puis-je utiliser la D-RTK 2 comme différentiel mobile RTK ?
I have a P4RTK + R-RTK 2 mobole station. Please, could someone in this forum help me know how to use D-RTK 2 as a mobile station ?
2020-8-9
mbuonanno
IRDAC Posted at 8-9 03:14
Hi IRDAC,
you can have a look at the following threads:
NEW D-RTK 2 "User Manual"!!!
https://forum.dji.com/forum.php?mod=viewthread&tid=188122
New D-RTK 2 Firmware Released
https://forum.dji.com/forum.php?mod=viewthread&tid=215468
Cheers,
Maurizio
2020-8-15
