S-e-ven
Flight distance : 5922034 ft
Tentoes Posted at 9-17 05:59
Not sure what you're asking.
The blue spark I USED to fly knew it belonged in FCC territory and just connected and worked. The yellow spark I fly now thinks it lives in CE land, so whenever I go to fly it has to change network settings. As long as I don't turn the transmitter off, it will keep the FCC settings as I turn spark on or off and change battery.
Tentoes, have you ever "ignored" that?
It is not a "I am not in FCC mode", this is a auto switching to the countries mode you are in, because "it things" it wasnt in that country, before.
That does not mean, it is not in FCC.
It is switching ALWAYS, after "crossing borders" and trying to fly in a different country.
Even if it is using the same settings here, like there.
On top, that was a go4 probleme, some time ago.
One of my birds has it, one not, I ignore it all the time.
There was a solution somewhere in the forums, over a year ago, I think. Something like changing go4 versions or such, for a reset.
But first you should check, how your settings are, after ignoring it. I'd say it is always in FCC |
