TPA_Brad
So I'm using a rental for the moment but seriously considering a purchase in the next few weeks, except for one issue and I need some advice. I have XT3 mounted and balanced from what I can tell perfectly on the Ronin-S. App says all is excellent. Firmware is most recent. Yet when I pan the camera with either the joystick or virtual joystick it rolls the horizon as it goes to 90 degrees from center. When I double tap to center the horizon doesn't immediately correct all the way to plumb but eventually it settles in. I've auto-tuned and calibrated and reset all settings numerous times. Am I doing something wrong or is this a defect of the design or a defect of the particular unit? At first I thought I just wonky balance on a job I was using it because of the battery grip and a mic mounted to camera which made it top-heavy, but stripped down to nothing but the body and the small 18 to 55 lens it does it.
