DJI Gamora
Picanoc Jack Posted at 1-24 00:35
Garmora this is still happening again, done the sign in sign out routine, January 24th 2020 , see what you can do from your end thank you.
Hi, thank you for reaching out. Just keep on syncing your flight records on the application, Jack for you to gain the exact flight records that you have, sometimes there is a little bit of delay on updating the flight logs but it will never be gone as long as you will not uninstall your application without syncing the flight records. Hope this helps. Thank you for your support! |
