Flycaster
Try to use the bottom USB port, way more robust. ONLY use the side port for charging. I would get a magnetic cable for charging Look here:
https://www.amazon.com/Magnetic- ... 568828672&s=gateway
And you just leave the little mag. connector in the controller all the time. Saves wear/tear on the port for when you REALLY NEED IT. And you will......
For using the simulator, controller to PC, again, use the bottom port. Look here:
https://www.amazon.com/Powerman- ... 568828780&s=gateway
Make sure nothing is plugged into the side port at the same time, if there is something connected to the side port, that connection disables the bottom port.
(except the little magnetic connector for above cable. It does not disable the bottom port (missing 2 pins).
