Ronin SC Focus motor Problem
4477 9 2019-9-18
Custom Tv
I Buy a Ronin SC on thuersdey, i work all saturday whith the motor focus ( on Nikon 7200 no conection whith ronin) but at the end of the day become to fail. I coudent make it work again,
I Belive and supous that's its stand alone (in conection whith the ronin but dont need to conect the camera)
https://www.facebook.com/customtvarg/videos/2331544257111278/
2019-9-18
Hi there, what is the color of the Status Indicator of the Focus Wheel? Please make sure it is solid green.
The range that the Focus Wheel can rotate the motor will be limited before the calibration. It is recommended to calibrate the Focus Motor to see if it works. GTScreenshot_20190919_181426.png
2019-9-19
Custom Tv
yes I do that  and dont work,
2019-9-19
Custom Tv
test2  Here is the test, the firmware its the last too https://youtu.be/rzmG3239DOw
2019-9-19
Custom Tv Posted at 9-19 12:44
Blinking red slowly means the Focus Motor is disconnected. Could you please refer to the manual to re-mount the Focus Motor? The Focus Motor can be mounted on either side of the camera, you may try both sides and please make sure the Focus Motor is mounted firmly: https://dl.djicdn.com/downloads/ ... User_Guide_v1.0.pdf
2019-9-20
Custom Tv
DJI Mindy Posted at 9-20 19:48
Blinking red slowly means the Focus Motor is disconnected. Could you please refer to the manual to re-mount the Focus Motor? The Focus Motor can be mounted on either side of the camera, you may try both sides and please make sure the Focus Motor is mounted firmly: https://dl.djicdn.com/downloads/Ronin_SC/Ronin_SC_Focus_Motor_User_Guide_v1.0.pdf
ye ok but what hapened if I dont conect my camera, It mast work Stand alone ¿or Not?
2019-9-22
Custom Tv
https://youtu.be/urp_j8Xpb08
I been using my sc and im verry happy, but I still coudent maake work again my focus, couse hace the problema thats the video shows
2019-10-9
Custom Tv
2019-10-9
djiuser_JM7YNgSowAST
Cyprus
DJI Mindy Posted at 2019-9-20 19:48
I have a same problem. I tried to install the motor to both sides, I tried to update firmware but nothing. Btw the motor pretty warm literelly after couple of minutes.
2023-9-11
DJI Wanda
djiuser_JM7YNgSowAST Posted at 9-11 08:05
Hello, there. Sorry for the inconvenience. May we know do you mean the focus motor does not connect to the gimbal?
2023-9-11
