JJB*
Flight distance : 12225059 ft
If DJI uses the standard barometer setting as reference ; reference is at sea level 1013 mbar - 15 degrees C.
For every 30 feet plus height the pressure drops with 1 mbar.
So indicating 240 ft = 240 / 30 = 8 mbar.
2013 - 8 = 2005 mbar.
Temperature have some effect as well, did not calculate that.
After take-off the baro height is reset to zero, that`s why in the app you will see values wich represent the actual heigt above take off point.
BTW not 100% sure if it works like this, have to go into the files as the height before zero-ing is written as well.
cheers
JJB
