Minimum Altitude when flying over water
1046 1 2019-9-22
ebiscaroK18
Flight distance : 2043409 ft
Dear DJI,
I read a few treads about loosign the drone in water. Filming at sea is extremely nice, but there comes more risk due to waves, wid etc.
I recently lost my dorne in water due to a manouver error too clsoe to the water surface.
I was thinking that a minimum flight altitude wich you coudl set whil eflying over water coudl avaoid a lot of accident. You already have a max altitude, what woudl be the issue in alowing user to manually set a minimum altitude when we fly our DJI product over water?
Thank you
Enrico
2019-9-22
DJI Tony
Hi, thanks for the inquiry. It is not recommended to fly the aircraft close to the water (within 2 m from the water). When flying above the water, the vision positioning function will turn off automatically and only the GPS and barometer are used for positioning. The aircraft may even drop into the water. We do appreciate your understanding.
2019-9-22
