Overall Status Letest Firmware "Abnormal"
7270 7 2019-9-23
TTP
Flight distance : 3002054 ft
M2P and smart RC
Callibrating the vison Sensors with DJI Assistant on PC
But noting coming up when a start the DJI Assitant 2 on my PC
Trying connecting with USB-cabel and without,  Smart RC or drone
Have over 200 Flight Time without problem, and now this.
2019-9-23
A J
Flight distance : 13864580 ft
You need DJI Assistant 2 for Mavic
2019-9-23
DJI Tony
Hi, we're sorry for the inconvenience. May we know what happened to the drone prior to experience this problem? We would like to ensure that the DJI Assistant 2 version is up to date, please download this link: https://www.dji.com/downloads/so ... nt-dji-2-for-mavic. You could also refer to the screenshot below for updating the firmware.
2019-9-23
TTP
Tanks, have calibrated to the Point wher I`m askt to fold rear proppellersarms,
the USB-kabel is in the way, somting is wrong with the instruction or I getit wrong.
2019-9-25
TTP
Have at last been able to come to the end of the calibrating process, not an easy task.
Instructions for the process could be little more extensive.
But I could still fly with the warning an all sensors function just fine.
After the calibrating the warning is gone.
2019-9-25
TTP
Sweden
Again, I received a warning about "Abnormal, Overall Status Letest Firmware",
so I have again undergone the very complicated procedure to calibrate the sensors,
time for DJI to create a more easy to use program for this.
2019-11-2
djiuser_7ZN1AydXPaPy
I also have the same problem and when i try to calibrate on dji assistant 2 for mavic I cant get passed the set up on screen. Only had this mavic 2 zoom for 3 weeks and getting problems..
2020-8-7
TTP
Sweden
djiuser_7ZN1AydXPaPy Posted at 8-7 15:31
Unfortunately, this seems to be the only way to calibrate the sensors that DJI offers.
I do it from a laptop with a built-in camera.
After several calibrations, I seem to get a slightly better idea of how to handle the drone in front of the camera.
Just to try again.
Good luck.
2020-8-7
