Smart Controller - Stream / Cast Video and Audio
7197 15 2019-9-23
cbaquol
Flight distance : 619826 ft
Not sure if people are aware of this, but I just discovered that the smart controller allows you to cast your screen to another smart device on the same network.
Settings->Sound->Cast->Enable Wireless Displays (in top right)-> wait for smart TV name to appear-> connect!
No noticable latency either. It does stay connected while the drone is in flight. This might solve some of the issues I've seen with guys trying to find a good solution for a second monitor. Why not a 65" 4K TV??
2019-9-23
Forestjim
Flight distance : 6606519 ft
Thanks.... I'll give that a try
2019-9-23
A J
Flight distance : 13926112 ft
Wow - thanks for sharing
2019-9-23
maddox
Cool! Thanks for sharing
2019-9-24
ff22
I had tried it quite a while ago but did get pixelation.  I should give it another go.
2019-9-24
DJI Gamora
Hi, thanks for sharing this amazing video that you had shared for us. Thank you for your continued support!
2019-9-24
Montfrooij
Flight distance : 2560453 ft
Thanks for the info!
2019-9-24
aerography.pt
Flight distance : 2012687 ft
Amazing feature! Thanks
2019-9-24
DennisMurry08
Flight distance : 5948264 ft
Have you checked the distance on this? Meaning can you be outside and transmit to a monitor inside?
2019-9-24
cbaquol
DennisMurry08 Posted at 9-24 16:19
I haven't, however it isn't necessarily a matter of distance. As long as the smart controller is connected to the same wifi network that the tv is connected to, it should work. Distance would vary greatly depending on the networking hardware in the home.
2019-9-24
cbaquol
Update - this no longer works. Somehow my smart controller was updated and the menu is entirely different with many more options making it more difficult to figure out. How the hell is it possible for it to just all of a sudden be updated without some kind of acknowledgement?? Is there a way that I can view and post some kind of update log?
2019-10-8
AmericanGhost
cbaquol Posted at 2019-10-8 16:01
Hmmm cbaquol, I just got my Mavic 2 pro with a Smart Controller and maybe I haven't applied the same update yet, but I discovered this same feature and it worked pretty well.  The wifi range on the Smart Controller kind of sucks.  If I got more than maybe 15 feet from my Orbi mesh hub the signal cut out... but it did work.
2020-7-7
AmericanGhost
Trying to edit my previous reply crashes my browser, so, sorry I have to add this addendum as a new message but I also found the cast option under DISPLAY as well as SOUND, so, perhaps try looking there cbaquol.
2020-7-7
bjr981s
Flight distance : 139698 ft
Does it require an Android TV?
2020-7-7
fans2b8c06e7
Hi the cast functionactivates the WifiDirect connection so the distance is between SC and the PC (I found 25meters max). I have then additional question: is it possible to cast only video and keep the audio on SC?? Thanks
2021-9-25
scubaAnn
Flight distance : 4425230 ft
I kinda want to try this!
2021-9-25
