H.264 UHD video frame rate ...
920 2 2019-9-24
Matthew Dobrski
Flight distance : 1831050 ft
Apparently Inspire 2 is offering only 30 fps maximum when recording H.264/265 UHD Full FOV video to SD card. Recordings with higher frame rate is utilizing cropped image, called Narrow FOV. Will CINESSD card allow for Full FOV, UHD video at higher frame rates?
2019-9-24
FVP
You can record 120fps in h264 (on sd card only) with full fov.
2019-9-25
Matthew Dobrski
FVP Posted at 9-25 07:35
Would you kindly support your statement with a screenshot of related setup page in DJI Go4 app? This will help to add a value to your revelation ...
2019-9-25
