AndyBoy
Flight distance : 10384 ft
DJI Susan Posted at 9-28 00:46
Sorry for the late response. It is recommended to write to , the designated team will take care of it. As you mentioned the unit was purchased from China, if you referred to China Mainland, I sincerely suggest that you may check whether your Chinese friends can help you handle the warranty claim due to the non-global warranty policy. Sorry about that.
Hi. I've given the description of the problem re: DJI Mavic 2 Pro Gimbal overload issue . What are the possible solutions - Do I need to look at replacing a cable, the entire camera, mountings etc. can you get your technical team to suggest. They must have seen a number of these problems already as many faces the same but no one is providing a solution |
