fans079c1359
I have the Ronin SC and I believe there is a mechanical problem. The arms are too weak. Try setting up the camera, balance it and turn the Stab on. Then give the camera a very slight tap on its top. And you will see the whole thing vibrate vertically because the arms are flexing. This is independent of the weight. I have a SONY A 7 III and used everything from a lightweight manual 28 mm lens to the Sirui 50 mm Anamorphic. They all shake, and the in built stabilization of the camera does not smooth this out.
If you balance the camera perfectly and do the auto tune I believe that indeed the stiffness settings will come out too low. Sometimes there is a small shake even when the whole thing sits perfectly still on a table.
At the moment I am helping myself by stabilizing the footage in RESOLVE but this cannot be a solution!
Pretty mad that they cannot make arms that will not flex. Add to this the problem that with longer lenses there is not enough clearance for the camera to pass the rear motor...back to the drawing board! I think this is very disappointing since the other Dji products I use work so well. |
