Ronin-S Release Notes (09/26/2019)
123Next >
25343 88 2019-9-26
thejamesnoble
Alejandro Ramos Morales Posted at 9-26 08:47
Hello! What is the best way to connect my camera to the gimbal? I'm very interested in the active track and pull focus features. Gear: ronin s, a7iii, batis 25 f2 & zeiss 55 f1.8
Thanks!
MCC Multi Cable
2019-9-27
Matias Zepeda
Activetrack and force mobile compatibility for iphone 7 plus?? i dont see on the list
2019-9-28
DmytroK
Matias Zepeda Posted at 9-28 05:48
The list is ONLY for the tested phones models. It doesn't mean that it won't work on iphone 7 plus. Actually, it should work without any problems.
Don't worry, just try it when you have a possibility
2019-9-28
Matias Zepeda
I think I'm going to die waiting for the full focus electronically on the a7rii
2019-9-28
djiuser_t6RTMAIzeCc4
Great update, thanks DJI!  Does anyone else have this situation, that you can enter underslung mode holding trigger from only mode 1? From mode 2 and 3 holding trigger just nothing happens when going udenslung and camera just fallow your movement.
2019-9-28
Librebowski
I just wanted to say thank you for bringing these features to the Ronin-S. I have one question however, while using force mobile I noticed it would be far more useful if you could invert the pan axis, if anyone has a solution please let me know.
2019-9-28
escore
Flight distance : 775568 ft
Super good news! Thanks!
2019-9-29
studio-prestige
Flight distance : 1350003 ft
Help!!After the upgrade, when switching from profile 1 to 2. the camera is centered. I don't need it! How to make the switch without centering?
2019-9-29
djiuser_zNHCfZJz0wGv
Hello,
i can't go into flashlight mode anymore by holding the trigger, maybe i missed something ??  if anyone can help, thank you.
2019-9-29
djiuser_zNHCfZJz0wGv Posted at 9-29 09:44
Hello,
I can go flashlight only from mode 1, in mode 2 and 3 it doesnt work, is this a bug?
2019-9-29
AntDX316
Flight distance : 3394731 ft
Activetrack is kind of garbage but I'm not sure if it's because I didn't setup the gimbals w/ the phone other than on the forward-backward slider but it's Activetracking like the Osmo 3.  It's not all that great like the Spark is.  Probably because the lack of 3D movements.
Tracking from a fixed point is crap.
2019-9-29
kolpakovichkir
Hello!
After the last firmware update of Ronin-S, my camera Canon 5D Mark III began to freeze, when i half press the record button on Ronin to focus. I use MCC-Mini cable to control camera from Ronin.
Please, help, what can I do to prevent freezes?
2019-9-29
kolpakovichkir
UPD to my previous comment. The last stable release was V1.8.0.70. The next one V1.9.0.80 caused this problem. The record button always freezes the camera(((
I've just downgraded to 1.8.0.70 and all is ok
2019-9-29
TheFly67
Flight distance : 8087 ft
Hello,
Is it possible to change the speed so that the camera goes slowly to the center point when double click the trigger.
2019-9-30
djiuser_02tPgUWACoXO
Oh looks good !
2019-9-30
DmytroK
TheFly67 Posted at 9-30 00:05
Hello,
I have already asked for such a feature before: https://forum.dji.com/forum.php?mod=viewthread&tid=197205
2019-9-30
RikDingo
Flight distance : 2358225 ft
Excellent update.
The active track works correctly if the light and exposure is correct
Not convinced by the force mobile but I don't care.
I now have an issue with the panasonic S1 : If I plug the usb-C from ronin to S1 and plug my hdmi monitor, The back display of the S1 is turned off. As soon as I unplug the usb-C, the display turns on again.
I did not have this problem with the previous firmware.
2019-9-30
Skyflakess
it's not on the list but it works on 7+.. i have 7+ so i can confirm this..
2019-9-30
Skyflakess
djiuser_t6RTMAIzeCc4 Posted at 9-29 10:31
are your firmware updated? press the "M" button 3 times (press quickly) to enter flashlight mode
2019-9-30
AntDX316
I just don't think Activetracking 3.0 can beat manual mode because it will go where you don't want.  It will assume the subject will go left but instead, the subject goes right making the video look off.
2019-9-30
youtube.com/rtrrey
Flight distance : 848038 ft
Your functions on the IR cable does not work from the V2.0.0.90 upgrade. I tested it from downgrading to V1.9.0.80 the previous firmware and it work perfectly, could you guys look into this issues ASAP.
2019-9-30
TheFly67
3d ORBIT not working, is it because of the new firmware?
#3: The 3D Orbit
2019-10-1
DmytroK
TheFly67 Posted at 10-1 01:43
#3: The 3D Orbit
It stopped to work in previous update (19 ver) if I'm not mistaken.
But you can almost make the same by tweaking the settings. I'll try to make a screenshot later.
2019-10-1
TheFly67
DmytroK Posted at 10-1 03:21
Oké Thanks
2019-10-1
Skyflakess Posted at 9-30 13:15
Sorry, i mean underslung mode. You can't go from mode 2 and 3 holding trigger, only from mode 1 works.
2019-10-1
Kore148
I'm having issues with mine after the update. I was testing Force Mobile when suddenly it disconnected. Now I can longer find the bluetooth. I tried downgrading but it fails at 99% with an error message saying "device Wifi(1) not connected!" which I don't understand because my wifi is working fine. Could my ronin-s somehow be broken without me physically doing anything to it? Or is the bluetooth broken? Or is this just a firmware issue?
2019-10-1
Skyflakess
djiuser_t6RTMAIzeCc4 Posted at 10-1 08:48
it depends on how you set the settings per mode. for me i can do underslung in Mode 3 only, the rest not. but if you set all modes to do underslung i think you can..
2019-10-1
Skyflakess
#3: The 3D Orbit
how to do this in the first place? i've been wanting to know but i have no idea the settings?
2019-10-1
fans38d40fcb
I have a canon c100 any word if it is going to work with the ronin s yet
2019-10-1
youtube.com/rtrrey
FebriKrist Posted at 9-27 02:41
It's same for nikon camera.. I can't start / stop video using infrared cable.. I am using nikon D 7100
I have the same issue upgrading it and the IR cable doesn't work at all, so I downgrade back. Not sure this is a proper place forum to post but haven't got any replies from anyone about this issue.
2019-10-1
Skyflakess Posted at 10-1 12:07
Hmm, thats really strange, i can't find that in settings.
2019-10-2
Dheylin
Flight distance : 338 ft
Since I update the lock til and pan axis doesn't work for me... if someone can help me i will appreiate it
2019-10-2
Dheylin
Mr.BobbyD Posted at 9-26 11:47
Update went swimmingly. I have tested Force Mobile to be working & Active Track too. I am having issues with the new 360 roll features. Pressing the Mode Button 3 times puts the gimbal into 360 roll position, but when I press the joystick left (or right) twice to initiate the new Auto 360 roll, the camera gets about 30 degrees through the rotation before it freezes up, jitters like crazy for about a second, then returns to centered position & restarts the auto 360 roll function. The issue repeats itself continuously until I press the Mode Button to change modes. This same issue occurs if I manually attempt to do a 360 roll using the joystick.
I've done a gimbal balance test and calibration and neither returned any errors. I used the app to switch to 360 roll mode & the issue still occurs. When I use the 3-toggle Mode Button press to switch to 360 Roll, I can confirm that the app sees the switch and sets the 360 Roll flag to "On." Lastly, Ive reattached the gimbal to my Windows 10 laptop, & done a "refresh" on the new firmware update and it went through (again) with no issues.
mine is working fine, just "press and hold the trigger" no longer lock the til and pan axis
2019-10-2
AnticipateMedia
Flight distance : 309626 ft
Unfortunately there seems no way to be update in OSX 10.15 Catalina. HornDIS driver doesn't load.
2019-10-8
MJ Pro
Flight distance : 390 ft
Help. updated to newest firmware but found a couple problems. 1st is when you hold the front trigger, the camera will still move a lot. 2nd is 'smooth track' fine tuning (or using the preset setting:high, mid, low) not working at all. Please fix this bug. Downgraded to 2nd newest firmware and I dont have this problem. But this firmware dont have active track. Alsp please fix smooth track because this is really important for ru n gun. Thank you
2019-10-8
sky_makai
Flight distance : 3397539 ft
I REALLY appreciate these updates!!  I'm wondering what 'opimization' has been improved in flashlight mode...
2019-10-16
__.HW.__
@ DJI Support, is it correct that with the latest firmware the balance test speed is much slower (read a bit cluncky), and that the autotune behaves different?
    Downgraded to the older firmware and they both run much smoother than they do now with the newest firmware.....
2019-10-16
nguyenanhphuong
Vietnam
There will be a new version gimball RONINS 2019 ????????????????/
2019-10-27
reiter.dom
Austria
Hello,
Hey,
i have the same Problem. With my old Settings i can't locked the orientation when tilt axis is working.
i don't know it's a bug or this is new.
2019-10-29
Mischelloart
Flight distance : 204984 ft
Slovakia
Hello,
I have problem with autotune... Every time i see on app same value for low, medium and high autotune.... When i after looking on video from my G7 i see little shaking... How to repair this problem ? Thanks
FW 2.0.0.90 Ronin S
2019-10-29
123Next >
